Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Remote won't work
I was using my remote controller in the morning and it worked fine then, but then in the afternoon it just stopped working, the batteries are ok, I even put in new ones just to be sure. The transmit light on the remote turns red whenever I push a button, and the lens on the tv is clean too. There was never any problem with changing channels to show possible dying batteries, when I tried to use it in the afternoon it just wouldn't work. I used both of the blue button settings (TV and DVD) when I was trying to change channels. Unplugging and replugging the TV didn't work. AndI can't flip through chapters while I'm watching DVD's either. Thanks for at least taking the time to read this, and thanks more if you helped. my sony TV wont work so as the remote i cat flip channels manually the only thing i can do is turn it on and theres also a yellow spot in the top left corner of my TV set
  • 297 Answers
Reset the default setting go to menu button and manualy do this.....
Posted on Jun 19, 2008
All 5 ceiling fan remote sensors not working
Check that the remote is working. Do this by using a digital camera and point the sender at the lens . If it is working you will see a blue/red dot on the viewer screen. It will move when you move the remote. You cannot see the beam but the digital camera can and shows it up on the view finder.
Mar 24, 2013 | Hunter Ceiling Fan Light Remote Control
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
Wii remote not working?
You got to sync the remote with your console to activate the remote
Aug 09, 2017 | Nintendo Wii Console
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Jul 12, 2009 | Universal Remote Control Hampton Bay...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remote won't work
hi, see if the right funtion is selected, tv, vcr, dvd.then if that does not help, get a universal remote. they don't cost alot or some don't good luck. hope this helps.
Apr 15, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Remote won't work
I would try 'waking up' the remote-Take the batteries out,press each button once then put the batteries back in.See if that works.
Jul 24, 2006 | Apex Digital AT2014DV 20 in. TV/DVD Combo
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
