Question about Solis Palazzo Espresso Machine
Solis Palazzo - Coffee grinder seems blocked
I cannot get the coffee to grind through the machine. It whirls around for a while and then the light comes on to add beans. Any tips?
  • bcupaddler Aug 14, 2008
    I have cleaned and reassembled the grinder a numbrer of times, it still will not grind properly
What area do I brush and how do i get to it
Posted on Jul 16, 2008
    Genius:
  • 1,036 Answers
Hi there!
This is most likely due to a build up of ground coffee at the edges, and the whole lot has become a solid lump.
Disconnect the machine and clean with a small stiff paintbrush.
This is caused by damp beans, or using dark roast beans, or keeping beans refrigerated. Often it is the coffee oil that causes it.
If there are beans in there and the unit is not rotating, please contact here again.
Thanks......Oh, and rate as Fixya! if it helps you.
Posted on Jun 19, 2008
Bean hopper is full, machine starts to grind the coffee but right before it starts to pull the shot, it stops & says "add beans to hopper".
the add beans to hopper signal most likely is triggered by the machine not sensing enough load put on the grinder (hence it thinks its out of beans) , this most likely is set by the grind (fine/course ) id say the grind is set to an improper size and the automatic sensor is picking up on that
another thing is the coffee / if its way too moist and not dry enough then its also going to trip the sensor as well
Feb 26, 2016 | Coffee Makers & Espresso Machines
Manual
Hold the coffee button down from the moment it is pressed till the water in the cup reaches the desired volume, then release. It will now save that volume amount to memory.
Jun 13, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Solis palazzo not producing coffee
I think the blockage might be at the brew unit, remove unit and check the screen under the red o-ring, connected to that is the chute that leads to the espresso spout. That tube might be blocked, there are 2 screws holding that piece together, be careful when you remove them do not lose the spring and ball in the fitting. Clean tube and reassemble.
May 24, 2012 | Solis Palazzo Rapid Steam Palazzo Fully...
Beans grind and are wet but coffee doesn't come out... it goes through the cycle and spits out a little. When cycle is complete, the water light comes on, but after priming the same thing occurs.
This tells me that either the grind is too fine and or the brew unit screen, and discharge tube needs to be cleaned. Try this first press the button for making a espresso using the manual function, do not add coffee through the door then press the brew button. If water flows freely then the grind is too fine, if you get the water prime error then the screen under the red o-ring on the brew unit needs to be cleaned.
Oct 19, 2011 | Saeco Incanto Classic Espresso Machine
Solis Palazzo : turn on machine the brew group does not position it self to prepare coffee.powder coffee, coffee, and espresso lights blink. Brew group is not removable from machine. machine has had light...
Hi
This is for a Vienna but it should work for you Palazzo. It will help you get the brew group out and reset so you can reinsert it.
http://www.fixya.com/support/r2296970-brew_group_stuck_t_get_out
Aug 04, 2011 | Solis Palazzo Espresso Machine
My machine will grind but no coffee is dosed. When I take the brew unit out and open the door above it ground coffee comes out but that same door does not seem to be opening to release coffee during the...
HI
If you don't hear a click 3 times your building up fine ground coffee inside the box that the door works. Your ground is probably to fine and you are using a shiney bean which has more oils in it. Your big dial inside the bean hopper should be on 10-12 and the small knob should be turned down to the neutral position. You might for the first try turn the big dial up to 16 and see if it will work. If it doesn't your going to have to clean the grinder. This is what grinding to fine does. It cakes the grounds.
Jan 19, 2011 | Solis Palazzo Espresso Machine
Coffee maker is making very mild coffee. Looks more like tea. ANything that can be done?
You may need to add more grounds. We use 1/2 cup coffee grounds for our 10-cup machine, and it comes out perfect every time. If you prefer to grind your own beans, use 1/2 cup of beans, then grind.
Nov 29, 2010 | Bunn 10 Cup Home Coffee Brewer
I have a Solis Palazzo machine. My question is:
HI When was the last time you descaled? This can have a temp lowering effect if you don't descale on a regular basis. Program you water hardness so its set on 4. This will tell you when you have to descale. Descals is not the same as cleaning. Its a special acid that disolves the deposits inside the boiler.
Jul 24, 2010 | Solis Palazzo Espresso Machine
Red warning light comes on in my saeco vienna deluxe I just aquired this unit and to date have not been able to make a cup of coffee. All the green lights light up and coffee starts grinding but after that...
Hi
More than likely your grind is to fine and you are using oily beans (shiney). There is a small knob in the bean hopper. turn it down to the minus side. Turn the big knob to the # 18. If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 07, 2010 | Saeco Vienna De Luxe Espresso Machine
Solis Palazzo Espresso Machine Logo
163 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
