Question about Hotpoint Dryers
The drum on my hotpoint VTD20 dryer is not not sitting level which has caused it to wear a small hole in the back plate. i would like to know how to fix it as it could just need a new bearing or bracket and therefore i would be able to fix it myself.
  • 66 Answers
The carbon brush on the back has worn out its square and about 13mm x 13mm this wears and causes the drum to drop and grindwould suggest a complete shaft kit cost is about 15 pounds from local spares shop or online hope this helps will sound like new once this is done regards jason please leave feedback as alot of people dont.
Posted on Jun 19, 2008
Noisey tumble in reverse tcm 570
your guide wheels that the drum rides on at the back of the dryer could b worn or where they sit on the post to turn on the actual wheel the center may b gone so wheel is wobbling instead of running . UNPLUG THE DRYER BEFORE U TRY THIS there should be an access door that u can pop off take a flaslight and look at back of the machine in the hole just under the drum on each side for cracked or worn wheels . Turn the drum by hand watching for any jumping of the drum if the wheels or the belt r bad this will cause that noise if u r a handy person u can usually buy a kitt where you get the new wheels and belt otherwise the other option . is to have repair guy come in to change it. there is also a felt ring that goes all the way around the edge of the drum this can either wear out or actually come off the drum this felt is also on the back of the drum when checking wheels u should b able to see it check for wear and tear
Oct 02, 2013 | Hotpoint Dryers
Rear bearing
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Feb 06, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Dryer clunking noise
hi try pushing drum at the top at the back if it lifts and nocks at all its the rear bearing cover on bake held by 2 screws you will see a pin through the shaft remove this lever bearing out to replace take lid off put bearing on shaft lift drum by rear edge so you can seat bearing
Jan 27, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
Aug 30, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint vtd20 tumble dryer is making a horrible grinding/grating noise when the drum is rotating and seems worse in 1 direction any ideas??
Jan 02, 2011 | Dryers
My hotpoint model NVLR333ETOWB, will not rotate drum
sounds like the belt is loose from a defective idler pulley
Oct 24, 2009 | Hotpoint NVLR333EE Dryer
Hotpoint tuble dryer, Aquarius, VTD20 makes scraping sound
sounds like the back drum shaft has worn and dropped through back[plate ... there is a fix for this by buying a new drum shaft and support kit comes with front bearing also .. can be a tricky job tho ....
Mar 30, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint vtd20 dryer aquarius - cuts out when overheats
You can get spare parts on line by going to,
www.hotpoint.co.uk
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Dec 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
111 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
