Question about Car Audio & Video
Citroen c5 estate heater blower will not switch off all other controls are working fine just the fan control says its off
  • penkwolf Sep 03, 2008
    hi. thanks for this post. i have been driving round with steamy windows for the last 3 weeks and found this post. brilliant!!! found the part and actually managed to repair it. there was crack in the solder on one of the pins. 2 mins and job done. however i know the part no now and they are about 50 quid with the VAT from citroen. cheers
    love live the internet!!!!
    Nigel
    Scholar:
  • 94 Answers
It's a common problem with the C5.
It is the blower fan controller. This is a unit about the size of a
cigarette packet and is found in the driver's footwell on the left, fairly
high up.
Valeo part number 509355 or Citroen part number 6441L2.
Buy a new part and just plug it in, make sure the ignition is off tho ;-)
Regards
Philip
Posted on Jun 25, 2008
Hi I have probs on xzara piccasso citroen heater switch fan and a/c switch not working cigar lighter also not working fuzes look good
Hi Francis there is a resistor pack in the heater box that controls the speed of the fan. They eventually give up. While you are in there try powering the fan direct just to check it spinns. Regards Jim...
May 07, 2015 | Citroen Cars & Trucks
Citroen blower fan not working
start the engine then turn blower on full and then reach under the passenger side LHD vehicles and thump motor with a clenched fist ,the brushes often stick and thump clears it and it works again for a while ,new motor 196 euros plus tax
Jan 27, 2013 | 2009 Citroen C5 2.0
Where is the HEATER BLOWER MOTOR FAN CONTROL UNIT on the citreon Xsara picasso 2005
Resistor pack is located in the lower heater fan housing and is accessable from foot well either drivers or passangers (could be either side) plate held on by some Torque screws
Jan 04, 2013 | 2005 Citroen Xsara Picasso
Picasso heater blower not working
Hi all. Yes this is a very common issue. 2 distinct issues in fact are common with the aircon.
1 you get fan on certain settings only. This is the resistor gone and johnjohn2 has identified the fix for this above. This is usually (although not always not intermittent and so you will usually lose all other settings over night and they don't come back
2 you get no fan activity at all. This starts to happen intermittently and then gets more frequent until the fans won't work at all. The fix for this is expensive through Citroen but cheap if you get the part off ebay. It is the ignition switch cable which has a fault. A very common issue. You need to remove the ignition switch and replace the cable from it. Work is not long but plugs can be tight and fiddly.
here is the link for the part
http://www.ebay.co.uk/itm/Ignition-Switch-Cables-Wires-PEUGEOT-206-CITROEN-XSARA-PICASSO-Lock-Barrel-Plug-/121038091531?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c2e6eb50b
good luck
Oct 18, 2012 | 2001 Citroen Xsara Picasso
Remove heater control switch
Before removing the heater switch on this 2006 citroen hdi I would first have the blower motor checked and the most common reason for this and other blower problems would be the blower resistor.
Your blower works on and off at times, first locate the blower motor and the resistor. the blower motor is located on the heater box, look under the pass/side of the dash, you may have to remove under dash cover to see blower.
When you have located the blower now look to the side on the heater box, there you will see a connector plug, it plugs into a connection on the heater box, this will be the resistor, the resistor slides into heater box and the end of it bolts to box to hold it in place and then the connector plugs into it, if you can not locate it then follow wires that plug into blower , follow wires back they will lead you to resistor,
next time blower does not work wiggle connector to resistor and see if blower turns on, if it does then resistor is the problem. also unplug resistor plug at resistor and check for any burning of connectors at plug and inside resistor.
I would bet its a bad resistor or the plug is brunt due to high draw from bad connections, if plug has burn damage to connectors then replace the plug along with resistor.
Jul 08, 2012 | 2006 Citroen C5 HDi
Ac blower motor
Check fuse supplying fan is not blown,
Check blower control switch is operating OK,
Check relay controlling fan is operating OK,
Check variable speed resistor pack is not faulty (the resistor pack is usually located in the blower ducting, in the blower airflow),
Check blower motor ground connection is not missing.
Aug 12, 2009 | 2000 Mercury Grand Marquis
LOCATION OF BRAKE SWITCH
It will be on the brake pedal assembly ussually at the top where the arm pivots.
May 17, 2009 | 2000 Audi TT
Car Audio & Video Logo
3,217 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
