Question about OKI MicroLine 420 Matrix Printer
Changing default paper size
How would I set the default page size to be 8-1/2 by 7-3/4 rather than 8-1/2 by 11?
    Scholar:
  • 130 Answers
Press & hold shift then press sel to enter menu mode. Press group until the group you wish to change appears in the first column. Press item until the item you wish to change is in the second column. Press set until the setting you want appears in the third column. Press and hold shift then press sel to exit & save your settings.
The default page sizes are; 11", 11-2/3", 12", 14", 17", 5", 3", 4", 5.5", 6", 7", 8", 8.5".
Posted on Jul 04, 2008
Xerox 7760 Wrong paper size error when trying to print to A4
First your computer selects the printer to output to, so make sure your default printer is selected.
Next, within your printer you may have selected a different page size for output as a default.
The printer it self should allow you to load and auto detect paper size. If this feature is not enabled see if it is a choice.
Also whatever you are trying to print check page setup in the program you are using make sure to ensure they match.
Sep 16, 2016 | Xerox Phaser 7760DN Laser Printer
How do I reset my SX215 to factory settings
When you are in the application that you are going to print from. Go to the menu bar, click on File - Page Setup. Here you should be able to change the paper size you wish to print out in. If you want to set the paper size by default to A4, then you will need to (Windows7) click on the Start button - Devices and Printers, select the printer that you want to change the paper size, right click on the printer - Printer Preferences, a dialog box appears, select the paper size you want in the paper size drop down list, click - Apply - OK. This should then have set the paper size to A4 by default.
Feb 26, 2015 | Office Equipment & Supplies
Changing paper size on ALC2600 from LT to A4
clear the print queue
then when you go to print click on printer settings and select a4 size click apply or make default
Mar 23, 2017 | Epson Office Equipment & Supplies
I am using Omnipage 17 through Microsoft Word 2003 wth an HP scanner. I am scanning text. The default page setting is for legal size paper, and there is a long list of paper sizes one has to scroll through...
Linda I suspect you can open a template called normal.dot and change the paper size then save the template.
see
http://www.geekstogo.com/forum/topic/131676-change-office-word-default-paper-size/ - the second answer given ..
Dec 09, 2017 | Nuance Communications Omnipage 17 Pro
When attempting to print from the internet, the printer does not print and the message in Status says 'letter not loaded in any tray, however the paper is loaded in the tray. I have lifted it out and...
I would guess you are loading A4 paper in the printer.
It is likely the Page Setup within the web browser you are using is set to "Letter" size paper, hence there is a miss-match between the size of paper in the printer and the size of paper selected in your web browser.
The method of changing the paper size in your web browser will vary from operating system to operating system and web browser to web browser.
Try looking under the "File Menu" look for "Page Setup" ensure this is set to A4.
You may also need to check the default paper size selected within the printer driver, again ensure this is set to A4 (if this is the paper size you are using)
Apr 02, 2011 | Lexmark Office Equipment & Supplies
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Brand new printer, paper stops in path
It's obviously not a brand new printer if the default has been changed, and if you're able to check that, then why not just try it?
But....
No, that wouldn't cause jamming, because changing the registration is simply changing the timing of the machine to move the image up or down the page, so regardless of the setting, it will still jam at the same spot. (I assume at the registration roller).
Is the paper setting set for the correct size and orientation of the paper you are actually using? That's what it sounds like to me. Otherwise, check paper switches.
May 21, 2009 | Ricoh Aficio SP C410DN Laser Printer
HP6110 default paper size for copying
Yes, manually set your paper size using A4 or begin with A4 and leave it on auto (default) it will try and match it.
Instructions...
  • Press Menu
  • Option 1
  • Option 2
  • Select copy Setup
  • Select paper size
  • Hit the black triangle until the size you want displays
  • Then hit enter.
Dec 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Page overlap
Try changing the range of print in your printers options dialoge box to 1 page at a time only. Typically, by default, printers are set to print ALL pages. Give this a try and see what happens. If it works then the page you are trying to print has spilled over the format limits set on one page by your program. To prove this out try lower the size of the FONT on the page you are trying to print and then see if it still prints more than one page. These steps should help you trouble shoot thsi kind of problem
Nov 09, 2007 | HP PSC 1510 All-In-One InkJet Printer
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
OKI MicroLine 420 Matrix Printer Logo
1,012 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
