Question about Kenmore Freezers
Freezer noise when my freezer shuts down. it makes a loud clunk sound
    President:
  • 1,462 Answers
Clunk comes from the compressor - possibly dismounted or sometimes assembly inside hits casing on switch off or switch on. no cure except replace compressor
Posted on Jun 19, 2008
Suddenly very noisy when running and makes a loud clunking noise when it stops.
Your Compressor is wearing out. Better be prepared for it quitting all together
Mar 09, 2016 | Kenmore Freezers
Very loud noises
Check the rubber mounts under the compressor and look for any lines touching the sides of the cabinet. The gurgling and clunking are often normal. good luck. Roger
Jan 19, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
My chest style freezer makes a loud clunking noise every so often. What could it be?
If you hear this noise when the unit shuts off, you might even feel it vibrate the floors. This would be a compressor that is on its last leg, I would start shopping, but you are in no immediate rush, unless its happened for quite a while.
Mar 21, 2010 | Freezers
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
Brand new unit, compressor noise.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
Apr 28, 2009 | Frigidaire 12.8 cu. ft. Chest Freezer...
Woods Freezer Makes Loud Vibrating Noise at 10pm each night
sounds like either your compressor is loose and just rattling or the compressor is off balance and its rolling around inside the seal can.  take a look at it when it is making the noise.   put your hand on the compressor (careful   might be hot)   if it feel like it running smoothly then i would call an electrician cause that kinda puts me out of ideas without being there...  sorry
Good luck
Jason
Jan 15, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezers Logo
129 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
