Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
LOCAL HD CHANNELS WONT COME THROUGH
I CANT GET THE LOCAL HD STATIONS TO COME THROUGH THE TV IT IS SET UP WITH SDT CABLE
Only has an ATSC tuner. Will not do cable QAM.
Posted on Aug 15, 2008
Tv picture changes and recording is unwatchable when trying to rec one of 4 local channels
It is the signal from the 4 local stations that is the problem, because you can record all others ok. Borrow another VCR and try to record them, if its the same tell the people who run the local channels that they are losing viewing figures, because their channels cannot be recorded.
Dec 27, 2013 | Computers & Internet
Do I have to subscribe to directv to get any high definition stations?
DirecTV provides the most HD content. But no, the correct off-air antenna may pull in local HD stations, depending where you live. Also, cable and DishNetwork provide HD channels.
Sep 05, 2012 | Vizio 32" e321vl flat panel 720p 60hz...
Cant seem to be able to get my local channels. i have a 52
I would suspect all the stations have gone away from over the air broadcast or gone digital for antenna reception---there are boxes available which will convert so the antenna can still be used.
May 21, 2012 | JVC Televison & Video
I don't now how i recive tv chanels in hd
Your source has to be in HD like a local broadcast TV station currently broadcasting in HD which you get with a VHF/UHF antenna connected to the HDTV. Most primetime TV shows are in HD so using the antenna on the HDTV is all you need. Press MENU on your TV remote and make sure you have ANTENNA set instead of cable to get local TV stations.
You also could use your local cable TV provider. You would need digital cable service and a HD cable box with HDMI or component video cable hookup to the HDTV. HD channels are typically above 100. Call your cable TV provider for more details.
Read your user manual for the LG TV. Ask for help from family, friends, neighbors, local electronics shops.
Mar 13, 2011 | LG 32LG30 32 in. LCD HDTV
My girlfriend has a toshiba 32rv530u TV. when she first connected it to her time warner cable everything worked fine. since then time warner has added free hd channels for the local commercial stations...
After u deleted all the HD channels u don't want.Tries unplug,replug the cable box back like about an hour.For the box to upgrade it softwares,should be deleted all the HD channels u deleted.
Feb 06, 2011 | Toshiba REGZA 32RV530U LCD TV
HOW DO WE TUNE THE TV FOR DIGITAL CHANNELS
If your using basic cable then just use auto program and the set does the rest. You will only get the hd stations your cable provider provides using basic. If you use their hd cable box and pay for more hd stations then you will have more.
Dec 03, 2010 | JVC LT-32X575 32 in. HD-Ready LCD...
Can i get regular tv
To get local over the air channels, you will need to connect an antenna as your signal source instead of Cable on the back of the set. Then you will have to go into the TV menu for signal source and select the Antenna/air option. Then you will have to go to the auto program/scan menu and scan in the stations. This may take a few minutes.
Now you can watch local stations for free.
I believe the FCC "must carry" rule require cable to carry local stations also.
Mar 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Not receiving my local cable stations
You need to make sure the TV is set for "cable" tuning and not "standard" or "air." (If you are getting only local off-air channels and no cable stations at all, be sure you have a good cable and connection to the set. Normally, even if the TV is set for "air" you will get the low-number cable channels 2-13.) This is usually a selection through the TV's set-up menu. With a universal remote, it may be difficult or even impossible to get to all the menu entries. Most replacement remotes don't support all the original remote functions. Try with yours and good luck. Once you get the TV set to the proper tuning, you should have all your cable channels.
Jan 03, 2009 | Durabrand BH1304D 13" TV
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
Get HD Signals but it Says Channels not available
you might have to look for "hidden" hd channels.
most cable companies are broadcasting the local stations unencrypted, so you should be able to receive them and sometimes a few other "basic" hd channels like discovery or tnt.
try googling your cable system, city and hd channels to see if someone has posted a list of channels (eg, 88-1 or 102-1)
Jan 12, 2008 | Panasonic TH-50PX75U Plasma HDTV
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
76 people viewed this question
Top Digital Lifestyle Televison & Video Experts
paul
paul
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
