Question about Kodak EasyShare C743 Digital Camera
Power on problem
Used this camera for a while. Inserted recharged batteries, turned on the display screen shows a weird image & does nothing. Changed batteries, same thing. Attached is a scan of the display. - Danny
  • 3 Answers
The LCD screen has gone bad, If the camera is less then one year old and youhave your receipt you can get it repaired under warranty. Go to the web site and fill out the form you will find under support.
Posted on Aug 09, 2008
Why wont my video camera monitor show up on my laptop when plugged in via usb
It could be you need to uninstall the driver and plug the camera in first and allow the laptop to install the software automatically.
Jan 23, 2016 | Uniden UDR444 Video Survailance System;...
Camera is stuck with lens out and won't turn on or
If this camera takes ordinary batteries you may have inserted them the wrong way around.
If it takes a rechargeable pack recharge it for average time recommended and try again.
Sep 20, 2011 | Sony Cameras
Black screen no image showing
black screen blur image showing cannot see subject to be photographed when camera power on,if press to take photo nothing shows, just black screen. it was fine one minute then nothing the next. battery is fully charged, memory card ok.
May 24, 2010 | Olympus FE-230 Digital Camera
Camera's screen is black, but still takes pictures.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, try pressing the DISP button once with the camera turned on.
Dec 18, 2009 | Canon PowerShot SD1100 IS Digital Camera
My Kodak EasyShare C180 Digital camera, came with "Kodak" batteries after those died, I inserted new batteries, and now everytime I try to turn the camera on, it doesn't respond. I have tried Lithium...
hi i just to have silimar problem with old panasonic, kodak and polaroid cameras.
try to use Duracel alkalines, not the cheap ones with out alkaline those are for remotes and clocks. flashlights.
if you are using rechargables make sure they are 2700mha AA NiMH or higher. lower won't work(there is another kind of rechargeables batteries those don't work on it).
for the lithium i never used them. they were kind of expensive compare to alkalines.
If i help. please rate me :)
Oct 08, 2009 | Kodak EasyShare C180 Digital Camera
Nothing shows on viewing screen
I had something like this occur with a minot mini video camera only it locked up in the "On" setting, meaning I could see a display on the screen but could not turn it off. I suggest you look very closely for a reset hole at the bottom somewhere, a place where a safety pin or the straightened end of a paper clip could be inserted. If no Reset can be found, then try holding in the Power On/Off for as long as 90 seconds. This may clear the problem. I would also suspect no power due to low charge or no charge on the battery, battery installed incorrectly, or battery not charged up.
Dec 10, 2008 | Casio Exilim EX-S600 Digital Camera
Stuck on Black screen
Hey buddy.....Know this first.....
Canon needs higher power batteries. You cant use Nippon of any other battereis that you use for clocks & other stuffs like torch..Buy a higher power battery....
TIP : Buy high power RECHARGEABLE BATTERIES. It cost you 200. Its must to buy a Battery charger. This combination will give you life long Battery.
No Hassles of Changing battery for every photograph...
May 05, 2008 | Canon PowerShot A450 Digital Camera
Mju 760 Problem, PLEASE HELP!
I am having the same problem with Olympus 710. error messge comes up as 5f08 5e02. i amwondering if anything could be done is I contact the company.
Dec 15, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
No images/picture:only right after turn on
Could be A. Battery contacts need a clean take them out and with the end of pencil eraser clean the contact in base of the chamber. B battery door losing tension - press it closed whilst in use. C. an internal connector worked loose try gently squeezing around the base of the screen- this usually where the connectors are. Do get onto Canon Tech Support Team. Just be prepared for a no repair solution. I.E. new camera
Jun 30, 2007 | Canon PowerShot SD10 / IXUS I Digital...
Kodak EasyShare C743 Digital Camera Logo
65 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
