Question about Maytag Dryers
Matag neptune washer wont start shows speed indication error any ideas?
  • 525 Answers
It doesn't work at all If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0088_11_1.asp#Level1_1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 20, 2008
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
How do I check the drain pump on Maytag neptune washer
I have a matag front load washer MAH6500AWW the door won't lock it just clicks
Apr 07, 2012 | Maytag Neptune MAH5500B Front Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer stopped working and flashed an FL error code. Any idea what that means?
It could mean flood error.if it has stopped full of water & it wont drain out.The pump might be blocked or jammed with hair pin or other debris.
May 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune front load washer keeps shutting off during the wash cycles. Any idea as to what is wrong and how to fix?
my matag neptune front load washer keeps shutting off durning the wash cycles,and the letters LP keep appearing.Any idea as to what is wrong and how to fix it?
May 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
Jun 04, 2009 | Maytag Neptune MAH7500A Front Load Washer
Matag neptun front load washer wont drain
You have a clog in your pump; have to dismantle to de-clog. Look carefully.
Tip:
Empty out all pockets in clothing before loading the machine!
Mar 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Speed indication error
IT WAS NOT TURNING FAST ENOUGH.UNPLUG FOR 5-MINUTES AND RETRY.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
8.8. on Display
Mine had a fried control board. $150.00 for the part, did the work myself. Will not be putting any more money into these Matag Neptune pieces of junk after this. Will buy another brand of washer and dryer.
Feb 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
52 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
