Question about Plantronics CS55 Wireless Headset
Plantronics CS55 headset.
My Plantronics CS55 headset suddenly developed a hum and will not really answer the phone. I had been using it heavily, so I let it sit in its cradle overnight in case the battery needed a recharge. No help. I can still answer my phone by picking up the handset.
Do I need a new headset battery? What could be wrong and how can I fix it?
Thanks!
  • 1,879 Answers
Greetings,
I also use a headset at work from the same company (Plantronics), If the battery is faulty it will not power and you can't use it.
The wiring has gone bad. Try re-connecting all wires.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 19, 2008
    Genius:
  • 3,422 Answers
The problem is with your headset.You'll have to replace it.
  • 13,433 Answers
The microphone at the tip of the headset may have a loose connection or a wire is cut, it may also be a problem inside the small microphone, warranty? get it replaced / repaired.
    Guru:
  • 1,894 Answers
Yes change the battery sir
also can be due to shorting
  • dewan nafees ahmed Jun 19, 2008
    the first chance is may be due to some improper power supply.
    u can watch the same kind of humming sounds in speakers when the power supply is not properly grounded.
    this is a similar kind of problem. if battery power is getting sorted or some other problem in battery u can have a chance of humming.
    the second chance u have is to check for any kind of shorting inside the headphones.
    u can watch the external wires first and then come for internal ones.
    at this stage if u don't get fixed by both first and second then change the battery and see if u get fixed.
    i think that must be ur final try.
    else u wil have to look for the address of ur service center.
    else replacement center if it is under warranty.
    feel free for asking any doubts u have.
    please don't repost ur question unless i don't respond to ur query.
    thank u for ur cooperation.
    good luck for getting fixed soon.
    have a great day
Plantronics CS55 Headset
Office was wired that way i have one tried several ways to use it without the lifter did't work had to buy a lifter the next problem is the phone not all will work Cisco uniden will work good
Jun 18, 2014 | Plantronics CS55 Wireless Headset
I was given a CS55 Plantronics head set. Looking for directions to set it up
If you click on the following page:
Towards the bottom of the page, click on the tab labeled ADDITIONAL INFORMATION. Within that section, you will see PLANTRONICS CS50/CS55 INTERACTIVE USERS GUIDE to click on. This will help you visually see how to setup and start using your CS55.
Good Luck from Headsets Direct!
Jun 15, 2011 | Plantronics CS55 Wireless Headset
I cannot here the phone ringing from my CS55 headset or another call coming in.
You will need the Plantronics HL10 handset lifter in order to have the CS55 ring, indicating an incoming call. The HL10 also allows you to answer remotely on most phones and hang-up remotely.
Plantronics HL10 Handset Lifter
May 17, 2011 | Plantronics PL-CS55 Wireless Headset
Incoming call alert
May 17, 2011 | Plantronics CS55 Wireless Headset
We have numerouse CS55 headsets that keep cutting out when speaking on the phone. Choppy sound, missing parts of words etc. Intermittent, will be good for 5 -10 minutes, then bad again.
The first thing to try is resetting the CS55. We hear this a lot and once reset, it usually takes care of the problem. It's equal to a ctrl+alt+del on a computer. Click on the following for detailed instructions and photos:
How to Reset your Plantronics CS55 Wireless Headset
Apr 13, 2011 | Plantronics CS55 Wireless Headset
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
Aug 04, 2008 | Plantronics PL-CS55 Wireless Headset
Best Buy: Plantronics Problem
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port.  Then plug the coily cord from the cisco receiver into the front of the CS55.  Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
Mar 21, 2008 | Plantronics PL-CS55 Wireless Headset
Plantronics CS55  Wireless Headset Logo
297 people viewed this question
Top Plantronics Radio Communications Experts
Ed Nelson
Ed Nelson
waldofrog
Level 1 Expert
sonic boom...
sonic boom...
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
