Question about Ricoh Aficio 250 Copier
Ricoh Aficio 250
The Machine is showing SC 306. What is the problem and how can it be solved.
  • 162 Answers
SC306: Charge roller home position error
The charge roller contact sensor does not detect the on condition.
Charge roller contact sensor defective
Charge roller contact clutch defective
Posted on Sep 14, 2009
  • Ricoh Master
  • 2,794 Answers
Turn the machine off and turn it back on. Usually the code is reset.
Possible charge corona wire error.
Does
Posted on Jun 20, 2008
  • Tim Babcock
    Tim Babcock Jun 20, 2008
    Does it come back during printing?
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
Ricoh aficio 2035 sc 322 (unidad de lazer en buenas condiciones) ?que mas puede ser ¿
sc 322 is a laser unit problem. find a ricoh technician and clean the laser unit or replace it. this laser problem is hard to solve usually.
Sep 28, 2010 | Ricoh Aficio 450 Copier
ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
Service call sc:543 for Ricoh Aficio 1515mf
plz do like this after again it shwos same then need to replace parts thermister,and thermal fuses. press the yellow 107 red and hold the red for two mints it shows copy sp.......like switch off on
Mar 25, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Error code sc 306 aficio 1022
I don't show a "306"....please re-check the code.
Have you tried turning off the main power (red button on front), and/or unplugging the machine to try to reset it?
Mar 18, 2009 | Ricoh Aficio 450e Laser Printer
I have a Ricoh 2045E I changed the toner and now get a SC680 error?
There are no SC 680 codes listed in the service manual for a 2045e
Please re check the code
Feb 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Oct 27, 2008 | Ricoh Aficio 250 Copier
The function key
hi whats the SC code showing up?
May 27, 2008 | Ricoh Aficio 250 Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 250 Copier Logo
261 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
