Question about Kenmore 22.0 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Light bulb I have a Kenmore side by side, do not know model number. Light bulb burned out, bought a new "appliance light bulb" put it in and it started smoking inside the light bulb and then burned out. Is there a specific bulb I should buy?
  • 1 more comment
  • kanorton Jun 19, 2008
    I got a 40 watt, does that sound right?
  • Anonymous Mar 16, 2014
    Light bulb is not the problem - light will not come on with new bulb
  • Anonymous Mar 18, 2014
    light won't come on, tried new bulbs
  • 833 Answers
Sounds like you got a defective bulb. Make sure it is for 120 volts or thereabouts....not 6 or 12.
Posted on Jun 19, 2008
  • Robert Hirst Jun 19, 2008
    Yes. It is possible that you jostled the bulb on installation. It the bulb is a screw bulb, be sure it is installed firmly. Before you put it in, have a look at the socket. Is it clean and bright or dirty? If not clean and bright and with the unit unplugged, use a pencil eraser to clean the contacts. Believe it or not, dirty contacts can burn out a bulb!
Can't read oven temp on control board.
Hello;
My name is Peter. I am a retire field service appliance technician.
The model numbers you provided are for wall space heaters.
Open the oven door the model number should be on a label on the face of the oven or on the side of the door.
Your control panel has red lights on it. Sometimes they burn out and you can not read the numbers.
Find the model number and go into the following website. Record the control panel part number. Search the web for this part number.
I recently, purchased a remanufactured oven control board for $45.00, when Sears wanted $256.00.
Make sure you ground yourself before you touch the control board, by touching something metal. Static electricity will knock out a control board.
Water Filters Lawn Garden Appliance Parts
Mae sure you turn the power off to your range before you start the work.
Feb 28, 2016 | Kenmore 95012 / 95014 Electric Kitchen...
On a Kenmore side by side refrigerator that has two light bulb sections, what causes the lights not to work?
The door switch provides a source of power to two things. Yes the door switch can be bad. What is your model number? There was some models that left the lights on when the door was closed and people would unscrew the bulbs just to sell them to people unaware. That problem was related to a bad relay on the motherboard
APPLIANCE 911
Nov 28, 2015 | Kenmore Refrigerators
Installed new brake lights, now smelling burning plastic...?
I would say you have the incorrect bulbs in them.
Mar 11, 2017 | 1997 Toyota Camry
Replacement light we need a new light on the
The bulb is a special bulb, take the model and serial #s to your appliance parts store and they can get the correct replacement.
Mar 04, 2011 | Kenmore Microwave Ovens
Turn signal light bulbs
you have corrosion in the socket which will cause the bulb to short out
Jul 30, 2008 | 1998 Dodge Caravan
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Fridge bulb burns out in fridge side
check to see if the light is turning off when you close the refrig door. its possible the door is out of adjustment and is not hitting the light switch properly when the door closes
Dec 12, 2007 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Dec 05, 2007 | Refrigerators
Refrigerators Logo
327 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
