You could have a build up of ink on your rollers, and as the paper is pushed through it is leaving marks. It could also be causing your ghosting effect or double lines. By having your printer cleaned by a certified technician it should reslove your issue.
I like this one!
No don't have a solution but....interesting
Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Unfortunately, Epson printers demand that both black and colour cartridges are OK before the printer will work at all. Now, if you are really sure that you only want to print black, the most cost-effective solution for you is to buy an Epson Chip resetter on E-Bay. This will reset your empty colour cartridge to "full", as far as the printer is concerned. You can then happily continue with your black-only printing.
Attention Windows Vista Users If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve: · 1) Disconnect your USB cable from your printer. · 2) Uninstall all Lexmark printer drivers on your PC. · 3) Download the correct Vista driver for your model. · 4) While leaving the USB unconnected, Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Go to www.lexmark.com and click on DRIVERS AND DOWNLOADS. Then use the DRIVER FINDER. In SEARCH BY MODEL, type in 1290 and you can choose a driver from there.
Did u clean the print nozzle's as well? If that does not solve your problem, you should try and replace the cartridge. (Colour in case of blue lines and black in case of black lines)
Prints are all dark. No color.
colors do not print, even after new cartridge and download/install of new drivers.
