Twice put new ink in printer. Photos/cards etc. all come out different colors No green grass at all I have cleaned a dozen times
  • pmfake1 Jun 20, 2008
    My apologies I thought I was speaking to Lexmark
    Genius:
  • 2,985 Answers
Much information Needed
what Operating system
What Printer
Which Program
You must know this dont waste our time
Posted on Jun 20, 2008
  • john ash
    john ash Jun 20, 2008
    Even Lexmark will wnat to know all this information
    Orovide the following always who every you speak to
    Computer operating system
    Printer Model
    Programs in use at the Time
    Type of subject.
Why is my printer printing out only green on my photos?
Check your printer cartridge. Ideally, there will be one for black and three for the colors; however, some printers only have 1 for color. If that's the case, then probably all the color ink except for green is gone from the printer cartridge. If so, you are going to need to buy a new color ink cartridge.
Dec 14, 2011 | Office Equipment & Supplies
Tells me ink needs replaced even after putting in new ink.
check your new ink catridge and look for a mini green electronic chip if that is damaged the printer shouldn`t recognize the catridge
May 16, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Color ink not printing, I have replaced the color ink, I have run all "cleaning" programs etc. When I print a page with some color or colors are a very faint gray. Any help ? No codes, flashing lights etc,...
It sounds like you have a severly clogged print head. The nozzles are likely gummed up and need to be cleaned. To do this, you need to inserta new set of OEM cartridges. Run the deep cleaning utiliity a half dozen times and then the alignment utility. This should clear the problem.
You have most likely been using aftermarket/reloaded cartridges with inks that do not meet the manufacturer's specifications. I would take them back to the vendor and ask for either a refund of replacements. If you are going to continue to use these cartridges, I would take out the OEM cartridges, reseal the two openings on the cartridge ( use electrician's tape) so that they can be used to clear the nozzles should they again become clogged with aftermarket ink.
Let me know if this solves your problem.
Mar 04, 2010 | Canon PIXMA iP90 InkJet Printer
Replaced Yellow cartridge. Photos came out
Clean all cartridges to make sure ink is flowing. To do this put windoww cleaner ino a container about ten mm deep. Put the cartridges with the end where the ink comes out facing down into the container and soak for about ten minutes. After this dry off for with a paper towell and make sur each cartridge leaks color into the towell. may take a little shaking.
Sep 03, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
HP 290 Color Copier no yellow color
I assume that when you cleaned the printer, you went into maintainence tab in the printer properties and hit the clean tab. We clean our printer heads this way and that always seems to fix the problem.
amsoilgirl
Nov 15, 2008 | Office Equipment & Supplies
Yellow is a greenish color
Try printing this test pattern. I got this from this other website. But as ridiculous as I may sound, did you put the yellow cartridge into the Cyan compartment? Because to produce green you need to combine yellow and cyan. This test pattern will tell you which colors are not working properly. Then we can trace which cartridge is the problem or not. Let me know the colors that come out.27dfd86.jpg
Jul 22, 2008 | Brother MFC-410CN All-In-One InkJet...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Mfc 240 c
Did you do a firmware update? If not go to brother homepage , download the update tool and do the update if it is avaiable.
Do you print with generic ink? If yes this prob is because of different color depth. Try to print with the original innobella ones or do some resettings within the printers properties when you print a pic from pc.
You may test the print out by printing directly from a picture card without pc.
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
35 people viewed this question
jasbo
jasbo
