Question about Intel Motherboard
Intel dq965gf mainboard
Does not see more then 2gb of ram, have 4 slots. if i put in 41gb ram it becomes very slow.
  • 818 Answers
Read this site
http://www.intel.com/products/motherboard/dq965gf/index.htm
told that the max reccomendend conf is 8 gb of ram.
Sergio
Posted on Jun 19, 2008
I put a 2gb ddr2-667 memory chip in the single (only) memory slot in my gateway nx100x notebook pc. The pc will not boot up with the 2gb memory card. Is there a compatibility problem or do I have a ba
yes, there may be compatibility problem. your 2GB ram may be dead. try your 2gb ram on other notebooks. if it is working on other notebooks, then your ram is ok. your notebook will support maximum 2GB ddr2 memory per slot. your notebook may not be booting due to unsupported frequency of your ram. maximum supported frequency for your notebook may me 400Mhz, and you are putting a 667MHz ram into it. try to put a 400MHz 2GB ddr2 ram in your notebook.
Apr 10, 2013 | Gateway Computers & Internet
I'm using an intel chipset G41 express in my pc but I don't know why each time I change my system, my graphic memory(1G) used decrease , first 700mb with win7 64bit and now it's became 256
Hello download the right drivers here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41RQ
Or install a better graphic card, in the pci-e slot on the mainboard for better performance.
The onboard graphic, is useing the physical ram on the mainboard to operate.
Support for up to 8 GB of system memory.
Support for DDR2 800 or DDR2 667 MHz DIMMs
Good luck
Jan 24, 2013 | Intel Essential DG41RQ Desktop Motherboard...
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
INTEL DQ965GF TRIED TO UPGRADE RAM . NOW WONT BOOT STICKS ON BIOS SETUP
the ram might not be compatible i had similiar issues with veritech ram
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope it helps
Jul 18, 2012 | Computers & Internet
I have a Gigabyte GA-K8VM800M Motherboard with 2gb ram. I want to disable the onboard graphics card and add another VGA card. Which card should I go for?? Will adding VGA card, show physical memory as 2gb...
Hello you can download the manual, and drivers here:
http://www.gigabyte.com/products/product-page.aspx?pid=1810#manual
You can add a graphic card 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
And Max capacity: Up to 2GB DDR400 RAM by 2 DIMM slots.
ATI/AMD makes very good graphic cards.
Adding a graphic card on the mainboard will not slow the physical memory. It has it`s own ram.
Good luck
Jun 18, 2012 | Gigabyte GA-K8VM800M Motherboard
How much ddr1 does 865gbf mainboard support?
Each slot can hold 1 GB of RAM. So totally you can install 4GB of RAM on your motherboard.Thank You.
Jun 30, 2010 | Intel (PENTIUM4PC2) PC Desktop
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
My mainboard is "Intel(R) Pentium 4 2.66GHZ 2.67GHz, 192MB of RAM." i want to upgrade RAM(DDRII(2GB)) and HDD(IDE((500GB)).Is my Mainboard support or not?
Your motherboard can support only DDR RAM not DDR 2.
You can upgrade it to 2gb that's fine.
And your motherboard can also support another Hitachi (500GB) IDE hard disk.
Mar 16, 2009 | Intel Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
Intel Motherboard Logo
159 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
