Question about Samsung Heating & Cooling
Where to buy filters for samsung split a/c's - Samsung Heating & Cooling
  • 40 Answers
Unless this unit specifies a special filter you can find them at Home Depot. If it is special check the numbers of old filter and go to manufacturer
Posted on Jun 23, 2008
    Champion:
  • 254 Answers
Try grainger.com
Posted on Jun 22, 2008
Samsung mini split outdoor unit won't come on, no led lights are on
Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. If it is then turn off power & wash it. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
Jun 02, 2015 | Samsung Heating & Cooling
Ductless split LG LS240CP keeps cycling on and off every 3 minutes without reaching room temperature
Any number of reasons. Low freon pressure is one. Dirty filter (wash with plain water) obstructions causing airflow problems. Don't confuse temp on remote with temp on face of unit. LG in the Philippines means "el gigawa" translation: fixalot! I owned 5 LG products all repaired multiple times. Now replaced with Samsung. If the unit is old, replace with Samsung $3000 or less but worth it.
Sep 25, 2013 | LG LA185HV Split System Air Conditioner
Sir, I would like to clear the filter. I have a split AC. Can you please explain how to remove the filter from the AC Unit Mohideen
you have to remove the front cover to access the filter. The cover should be held in with push button retaining clips. After you remove the cover the filter resides in front of the evaporator.
May 02, 2011 | Samsung AS18A6RB Air Conditioner
Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
May 08, 2010 | Samsung AS18A6RB Air Conditioner
SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
Sep 02, 2009 | Samsung Heating & Cooling
My Samsung air conditioner which is of split type is not operating. It is of the AS185 series. There is a red-light that is on. This has never happened before. It turns on momentarily and turns off again...
After 15 months of used my Split type A/C model AS18F series suddenly not cooling, I unplugged the unit and clean the Air Filter as well, but still the problem exist.
Apr 19, 2009 | Samsung AW1003M Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
