Question about Neff 24 in. S5443X2 Built-in Dishwasher
My dishwasher does not turn on
I have changed the fuse cleaned the filters the power is on and the water is on but the light does not come on and the machine doesn't start
  • 1,462 Answers
Check socket is ok - plug in something with a light into the same socket as an easy way of checking. otherwise go to where mains terminates on the appliance and check power is actually present - you will need a multi-meter
Posted on Jun 19, 2008
My double drawer kitchenaid dishwasher sold red light and beeping during cycle wont turn off and runs even with door open, turned breaker off
If you using upper or lower drawer and this shows up it means the dishwasher has water under the filter board which located on the bottom under the lower drawer. You have to disconnected power,removed the lower drawer, clean the water, replaced filter board, check the dishwasher for leaking.
Nov 26, 2017 | KitchenAid Dishwashers
No power after blocked drain dishwasher
Reset it by turning power off to it or unplugging it for a minute. If it still wont work then you need to take the kick panel off and see if there is leak under the machine.
Feb 08, 2014 | Smeg Dishwashers
How do I change or clean the filter on my Lamona 8362 dishwasher ? I do not appear to have been given a user manual Thanks
  • 1 Wait until the dishwasher has completely cooled after use before attempting to clean the filter. Turn the dishwasher off and unplug it from the power supply.
  • 2 Remove the lower dish racks and locate the filter compartment on the bottom of the dishwasher.
  • 3 Unscrew the filter housing and gently pull to lift out the filter.
  • 4 Use a few drops of dishwashing liquid, warm water and a soft-bristled brush to clean the filter and the filter housing.
  • 5 Dry the filter and the housing and reassemble them. Reposition them in the bottom of the dishwasher and turn until locked into place. Replace the racks and close the dishwasher door. Plug back in to the local power supply.
  • Jul 07, 2011 | Dishwashers
    I have a fisher & Paykel dishwasher, at first it would not empty all the water out, we have now manage to get to empty, but it now appear not to change programs.
    If you have the child lock function on then you are probably not able to change the controls. Disable the child lock if that is the case.
    The cause of water not emptying could be many. Program was not complete, filter is blocked and so on.
    Try to turn off the power and on again. See if it makes any difference.
    Follow the user guide to clean the filter plate and the drain filter. Try to run the empty dishwasher on the current program (if you can) with a cleaning kit which you can get from super market.
    Finally, clean the edges of the drawer with damp cloth including the program buttons.
    Hope something will help.
    Dec 15, 2009 | Fisher Dishwashers
    Dishwasher gets no water
    It is no fuse in dishwasher.
    Solution1: Check if the inlet line to d/w is open(usually it located under the sink)
    Solution2: To rich a fill valve filter:
    1. Shut off water to d/w kick panel under front door of d/w
    3.disconect the water line on left hand side
    4.pull filter from center of water valve by nose pliers
    5. clean the filter by old toothbrush under the sink
    6.put everything back
    7. if does not help the water valve needs to be replace
    Nov 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
    No clean dishes
    Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
    • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
    • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
    If your filter is clogged, it may be causing the cleaning problem.
    Drain valve
    Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
    Spray arms
    There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
    If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
    Detergent cups
    Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
    If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
    Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
    CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
    Sep 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
    1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
    2. Door switch
    Replace if defective.
    3. Timer
    Replace if defective (note: uncommon problem).
    4. Selector switch
    Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
    Indesit IDL 530 Dishwasher
    Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
    Apr 12, 2008 | Indesit Dishwashers
    Neff 24 in. S5443X2 Built-in Dishwasher Logo
    342 people viewed this question
    Top Neff Dishwashers Experts
    Cesar Quant
    Cesar Quant
    Michael Galve
    Michael Galve
    Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
