Emachine t2642 power supply - Computers & Internet
    Problem Solver:
  • 12 Answers
Apparently this model has a bad motherboard, which manifests as a power warning and eventually a refusal to boot up. You can replace the power supply (as far as I know, any generic one 250-watt or better will work) but it's unlikely to help. You can buy a new motherboard (and new power supply, if you want to) direct from eMachines, but it's also likely to fail pretty soon. Your best bet is to get a new computer (NOT an eMachines one) and put your hard drive in as a slave so you can get your data off.
Posted on Jun 19, 2008
5 Suggested Answers
  • 21 Answers
SOURCE: eMACHINE T2642 W/ IMPERIAL GV20030812
Can you provide at bit more info?
You say it wont power up, are you getting any power through at all? DO the LEDs light up? Can you hear the noise of the fans etc powering on?
Posted on Mar 23, 2008
  • 55 Answers
SOURCE: i have an Emachine T2642.hears a pop and the power went out on pc
As long as your hard drive didnt go, you will still have all of your files. Chances are your Motherboard blew. Motherboards have capacitors so they can make popping noises if they blow
Posted on Nov 30, 2008
  • 62 Answers
SOURCE: old emachine T2642 will not
It sounds like a dead motherboard. Try removing the CMOS(BIOS) battery and replacing it. Then try removing and replacing the CPU as well. If you get the same result then you might be looking at replacing the motherboard.
Regards
Posted on Dec 20, 2008
leecom72
  • 4806 Answers
SOURCE: need2 know wiring diagram 4 power supply 4 a emachine T2642
Hi there
The power supply should be ATX 20pin connection and also a 4pin connector, look at this picture below so you know you have the power connections in the right places>>ba37bd3.jpg
On the top left of the picture, the big cream 20pin socket is where the 20 pin connector goes.
In the middle to the left you will see another cream 4pin socket is where the 4pin connector goes.
If your power supply does not have the 4pin connector the pc won't boot up, you will have to go out and buy one.
If you have all the connections right and the on/off button is connected to the front panel properly, take out the system memory, clean it with a clean, dry, soft pain brush and also clean the slots too, re-seat the memory and reboot the machine to see if it boots up.
Good luck and thanks for using Fixya!!!
Posted on Feb 19, 2009
I have an emachine T2642 desktop and I need to replace the battery. Where is the location to replace the battery
A desktop machine does not have a battery, only a power supply. Unless you are talking about the motherboard battery which is located on the motherboard inside the desktop, but if that is the case I highly suggest having someone at a local shop swap out your battery. Making a mistake could ruin the motherboard.
Apr 10, 2011 | E-Machines T2642 PC Desktop
T2642 Emachine upgrade,can you recamend parts that are compatable 1GM memory. Hard drive 160 MG Viteo memory over 128 GB Thanks
Use this site to help you upgrade you T2642 e-Machine. The link shows what can be upgraded. Includes max memory the system can run;
http://www.cputopia.com/emachines-motherboard-case-cpu-replacement-t2642.html
Hope you find this helpfull.
Mike
Oct 21, 2009 | E-Machines T2642 PC Desktop
Need2 know wiring diagram 4 power supply 4 a emachine T2642
Hi there
Feb 19, 2009 | E-Machines eMachines Desktop PC
Power up
if no power light indication then, probably the power supply got fault. please try to test your power supply .
melnavz
Dec 23, 2008 | E-Machines eMachines Desktop PC
Old emachine T2642 will not boot...disk monitor LED stays on and CPU fan does not rotate...no boot access to CD-ROM, or disk drives...changed power supply...think it might be BIOS backup battery...
Regards
Dec 20, 2008 | E-Machines T2642 PC Desktop
Emachines T2642 Motherboard
It's either a dead power supply or a fried motherboard. Emachines are cheap junk, their power supplies and motherboards die all the time, just look around here on Fixya for proof. Instead of saving a buck, consider buying a better brand.
Dec 02, 2008 | E-Machines T2642 PC Desktop
I have an Emachine T2642.hears a pop and the power went out on pc
Nov 29, 2008 | E-Machines T2642 PC Desktop
EMACHINE T2642 W/ IMPERIAL GV20030812
Mar 23, 2008 | Computers & Internet
Computers & Internet Logo
303 people viewed this question
David Payne
David Payne
