Question about GE WBSR3140DW Top Load Washer
Ge washing machine removing side to look at inside
I am trying to take off one of the sides to look at the inside of my machine to see if a belt is broke because it is making a sound like it is out of balance, but it is not.
Thank you JBJAXiII for helpjing me to remove the front on on washer. You were a life saver and saved me alot of money I'm sure. Thanks Franklin1650
Posted on Jul 04, 2008
  • 95 Answers
Should be 2 clips under the front of the machine, just below the top. they should be able to be pushed slightly in to release from the front panel
Posted on Jun 25, 2008
Wiring diagram of pressure switch
All Ge washers should have a wiring diagram inside the control panel on the left side if standing in front of the machine. Hopefully it wasn't removed by someone.
Apr 01, 2015 | GE WPRB8050D Top Load Washer
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
My ge washing machine won't spin - what's wrong with it?
  1. Your motor may need to be re set. unplug the machine for one minute then plug it back in. You now have 12 seconds to lift the lid and close it six times.. it only needs to be open about six inches.. this re sets the motor. if that does not work check the belt by inserting a putty knife approximatly six inches from either side to release the clips while pulling forward on the front panel to remove it. look underneath to see if the belt is in place or broken.
Jan 19, 2011 | GE WDSR2080D Top Load Washer
Water leaking during wash cycle. How do you get access to inside
I use a putty knife about 2" inward , between the top and the front panel on each side . Give a good hit on one side while slightly pulling the front panel forewafd . Then do the other side . The front panel tilts foreward and hinges on the bottom with tabs . Then lift to remove .
Aug 02, 2010 | GE WBSR3140DW Top Load Washer
How do I remove the front to check the insides??? I think the belt is broken
Place a flat blade metal putty knife on the right and left sides of the front at the top where the front panel meets the top panel. There is a metal clip on each side that locks the front in place. Push in with the putty knife between the top and front and you will feel these springs. Press in one at a time and pull out gently on the front and it will come off.
Jun 27, 2010 | GE WBSR3140DW Top Load Washer
Remove front panel on ge washer
Use a putty knife and press in the panel clips located on the top left and right sides where the front panel meets the top lid. They are about 3 inches in from each side.Press on the clips while pulling forward on the front panel.
Jul 25, 2009 | GE WBSE3120B Top Load Washer
How to change a washing machine belt
Unplug machine. Remove back panel. loosen three nuts holding motor clutch assembley from bottom side of motor mounting plate with deep well socket, allowing motor mounting plate to slide. Remove clamp holding flexible drive coupler just above belt. Remove belt. Reverse to install, but remember to give a little tension to the belt by holding motor toward the back left corner while tightening up nuts. Tighten the nut closest to the center of the machine first.
Jul 09, 2009 | Washing Machines
I need to replace the belt. What is the easiest
tip machine on it's side, than remove the bottom panel, you will now have access to the belt.
Jun 22, 2009 | GE Washing Machines
GE Spacemaker stackable washer/dryer
The front cover come off by removing two philips screws on the bottom of the panel. That will expose all the operating parts of the washer.
Sep 17, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Ge prodigy wpse4270aoww won't rinse or spin
try to clean out the water pump lines from pump to out to the drain
Feb 25, 2008 | GE Profile Prodigy WPSE4200A
GE WBSR3140DW Top Load Washer Logo
96 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
