Question about Brother Office Equipment & Supplies
Hi there: I recently bought a Brother MFC 240 all in one. When I copy anything either black or colour on my printer it leaves a verticle black line on the page. This black line is a bit off centered. To me it seems like a dirty roller. How can I clean this roller it is very anoying and I am using it for business and it looks very unproffessional. Your help would be appreciated. Thank you.
    Scholar:
  • 130 Answers
There is probably white out on the scanner glass in the area where the line is. Look on the glass by tilting up the document feed assembly and using a flashlight look on the glass.
Posted on Jul 04, 2008
    Novelist:
  • 150 Answers
1) The first step is to determine if the problem is in the scanner, the printer or in the internal electronics... 2) Try printing an existing document from your computer. (without scanning). 3) Next scan a full size color photo into your computer, without actually printing it. Now check the document with the Windows default image viewer. (use a real photograph, painting or high quality magazine, avoid dotty news or mag photos which will cause Morie patterns (Light and dark color bands) due to dot-pitch interference) 4) If the scanner works fine and the printer does not, remove all ink cartridges and clean the printer rollers with dilute rubbing alcohol. 5) If the scanner is the problem, and the glass is clean, take the printer back for warranty. (scream blue murder) BTW The reviews on this combo are quite poor: 1) Flimsy construction 2) Frequent paper jams 3) High Ink usage 4) Refuses to scan if even a single ink cartridge is empty. "All in ones" are generally NOT a good bargain, unless they are laser based, due to a very high (total) cost of ownership. It is best to analyze your needs: 1) Use a low cost laser printer for ALL black and white printing, it is astronomically cheaper, reliable and hassle free. The print quality also far exceeds ANY color ink-jet. A great Brother laser jet can be purchased for less than $100, which is roughly the cost of a complete set of ink cartridges, the images are nothing less than perfect, and the toner lasts for ever. It is also very fast. 2) Use an ink-jet for color photos only, and for the occasional pie chart. If you do a lot of color printing, invest in a color laser for business documents. Color ink-jets produce the best photos on glossy paper, but they are slow, temperamental, and consume tons of money in replacement ink, whether you print a lot or not, because they dump ink during frequent self-cleaning cycles. Ink-jet printers are designed to be given away, like free **** samples, so that the manufacturers can make a killing on you later. Laser printers are excellent for high resolution and high volume printing, but the colors are not as bright. For B&W, though, they are infinitely superior. Finally, ink-jet prints will smear if they get wet and they also require more expensive paper. Laser prints are "Baked on", which makes them far more durable. Also, color printers have far less pixel resolution than the advertised dot-pitch, because many dots are required to produce the illusion of a single color pixel through "dithering" 3) Good scanners are also cheap < $100 Put the 2 together with a PC, and you have a copy machine. Add a modem/fax and you have a fax, or you can attach your documents in a locked PDF format to an email. Hope this helps. Martin
Posted on Jul 01, 2008
The "scanner" has a series of light detectors and one or more is not working. There is nothing you can do as an end user to fix this. You need to get it replaced. Typically it is the manufacturer that will do the replacement, not the seller. Contact Brother at once and let them give you a return authorization number. Typically the manufacturer wants to clear these problems up as quickly as possible.this are also my suggestions
thanks
Posted on Jun 27, 2008
    Novelist:
  • 148 Answers
I guess my first question is What side is the mark on , The printed side or the back? A the second is how long have you had it and have you ever refilled the cartridges by yourself. Let me know and we can work from there...Be mucho blessed...mark
  • 81 Answers
If you know how to open the scanner side just clean the mirrors near the light bulb. clean it with blower black line usually cause by foreign object in the mirror. i hope this will help
Posted on Jun 21, 2008
    Problem Solver:
  • 9 Answers
Sometimes dust get stucked on the scanner glass or if you have ever corrected a document with those white liquid correcting solutions and passed the paper into the scanner before the liquid is completely dry, it gets a bit of the correcting solution on the scanner glass and every time you copy or send faxes, you will see vertical lines on the copies and the faxes at the receiving end. Just cleaning the glass carefully can solve the problem.
Good luck
Posted on Jun 20, 2008
Sdfg
    Novelist:
    Scholar:
  • 70 Answers
  • 51 Answers
Sorry but if that line is printed with ink then thats not a roller but the scanner has malfunctioned. If you cannot replicate the mark when printing normally then it is not a roller. Contact the seller and get a replacement
Let me know
Fred
Can i just some how on just black ink only on the brothers 240-c
Hi there
Sorry not can do, not work it made to see all the inks working or not work
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
Black ink does not print on brother 240c
If you haven't changed it recently, it may be out of black ink. The product code for Black is LC51BK.
Brother's supply site
Dec 10, 2009 | Brother Multi-Function Center MFC-240C...
MFC-490CW two ink colours just not printing, it still prints biut just with black and blue, tried cleaning them the normal way but they still wont print. Cant get into maintenence mode to try better...
Powerful cleaning is: Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 10, 2009 | Brother MFC 210C All-In-One InkJet Printer
We recently bought new ink cartridges for our brother mfc-240 printer. It keeps saying no cartridge wether we put the new or old black one in. Is this fixable? -Rebecca
The machine most likely want you to change one (or more) of the other cartridges too. By opening the top cover and reading the display when it is opened, you should get an error indicating which cartridge to change, it most likely isn't the black one it is alarming about, but rather one of the not-changed ones.
Jun 03, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a brother printer and I recently bought black ink and it wont work in less i have all the colors....is this normal or is there something I can do???????
Brother machines will not work unless there is ink in all the cartridges.
This is done on purpose to make sure no air enters the ink tubes. You will have to get new colour cartridges or you will have to remove them and put black tape on the sensor area of the cartridge. This will make the machine think the colour cartridges are always full. This will also cause air in the ink tubes, and thus dry out the colour portion of the head. Once dry, it is unlikely you will get the colour working again.
Apr 16, 2009 | Brother MFC 420CN All-In-One InkJet...
I replaced all the ink and my brother mfc 240 still wont print black, or copy black, or test print black
i replaced all the ink and my brother mfc 260 still wont print black, or copy black, or test print black
Mar 24, 2009 | Brother Multi-Function Center MFC-240C...
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Colour ink runs out and can't print b&w page
with all brother printers all the ink cartridges must be full or the printer will not print brother tech
Oct 27, 2008 | Brother MFC-465CN InkJet Printer
650 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
