I have an Aspire 5024
Can I do a System restore even though I have mislaid my System Recovery Disc?
bobmax98
  • 2,326 Answers
Yes, you can do a system restore. If you have windows XP, here's how is done:
Press "start > programs > accessories > system tools > system restore.
Once you open the system restore windows, click on Restore my computer to an earlier time, click on next; now is when you need to know when the audio went missing and do the restore to around the time you found out that the audio was gone.
Good Luck.
Posted on Jun 19, 2008
How can I make recovery disk for an acer aspire one AOA150 with windows xp?
Check out this WEB site on how to make a System Restore disc.
http://forums.cnet.com/7723-6142_102-310061/how-to-create-your-own-xp-system-restore-disk-guide/
Jan 21, 2012 | Acer Aspire One PC Notebook
I want to restore my acer aspire one to factory settings
to restore your computer to factory settings, you would need a recovery disc from the your computer manugacturer, you can call them and seek assistance for them to send you a disc and help you install the recovery disc.
May 10, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi guys, I have an acer aspire 9300 series, i did noy get a recovery disk with it because its supose to be on the hard drive.the problem is that when i try to restore to factory default it keeps booting to...
if you want to recover your laptop to factory setting, juat press Alt+F10 at acer logo displayed
you will directed to acer recovery management, from there you can recover your laptop
Mar 12, 2011 | Acer Aspire 9300-3642 Notebook
Error Oxc00000e9 when i turn on aspire 5741, no external devices plugged in.
try this below
First please refer to the following thread to see whether it helps.
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=796452&SiteID=17
I know that you are unable to start the current vista operation system and getting the error 0xc00000e9; the issue can be caused by the damaged system files or hardware device. You might first follow the steps below to exclude the possibility of system corruption.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Feb 14, 2011 | Acer Aspire 5050-3371 Notebook
0xc00000e9
Hello.
This error can refer to hardware or software, depending on various circumstances.
Most likely, you have damaged system files.
You didn't indicate, but figuring that you have Vista, run System Recovery:
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
Hope this helps.
Jun 17, 2010 | Acer Aspire 5050-3371 Notebook
Need to restore my acer aspire to factory setting but never got a recovery disc at purchase,how do I go about doing this as i am not that technically minded
"Restoring a system should be a last ditch effort in trying to repair a computer, since restoration causes all programs and many files to be lost forever. Restoring an Acer computer to its original factory settings can be done in a few easy steps."
  1. Click “Start” menu.
  2. Click “Programs.”
  3. Click “Acer Recovery Management.”
  4. Click the “Restore” button on the bottom of the dialog box that opens.
  5. Click “Restore System to Factory Default.”
  6. Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
  7. Click “Start” to restore the computer to the default factory settings.
Dec 31, 2009 | Acer Aspire 5315 Notebook
I have an ACER Aspire 5920 running Vista, but I have mislaid the recovery disc and the computer no longer boots up. Can I down load Acer Recovery Media onto a disc to boot and repair windows from?
How old is the system? If you have not fully repartitioned & reformatted the drive, you should have an option or prompt while the system boots to either enter setup or a boot menu. If you choose that option {PRESS F8, or some function key}, it will put you at a menu to restore your system.
Most Acers, as well as any major computer companies come with a section of your hard drive set aside with what is called a "flat" of the factory install. This is either a compressed mirror or installation of what was on your system when you first opened the box.
You can find the details for your specific make/model by going to the support section of the acer website.
Oct 07, 2009 | Acer Aspire 5920-6727 Notebook
System Restore
Recovery procedure for Acer netbooks.
Important Information
The Recovery disc will help you to restore the hard drive with the original software content that was installed when you purchased your notebook. Follow the steps below to rebuild your hard drive. Your drive will be reformatted and all data will be erased. It is important to back up all data files before you use this option.
Restoration procedure:
1. Press the power button to turn the system on.
2. Select to boot from a USB optical drive. There are two ways to do this:
2.1. Press <F2> during the Power-On Self-Test (when the Acer logo is displayed onscreen after bootup) to enter BIOS Setup.
2.1.1. Select the Boot menu.
2.1.2. Refer to onscreen instructions to set the first device to any bootable optical disc drive.
2.2. Press <F12> during the Power-On Self-Test (when the Acer logo is displayed onscreen after bootup), and select the USB ODD from the list that appears.
3. Ensure the Recovery disc is in an external (USB) optical disc drive, and exit the boot selection menu, by selecting Exit Saving Changes from the Exit menu or pressing <F10>, or by pressing <Enter> as appropriate.
4. Select Exit Saving Changes from the Exit menu or press <F10>.
5. Follow the onscreen instructions to complete the installation process.
6. When you finish the recovery process, please remove the Recovery disc and insert the System disc again.
7. Restart your computer.
Jan 25, 2009 | Acer Aspire 3000 Notebook
 Grubhead
Grubhead
