Question about Toshiba Sattelite A105-S2071 Notebook
Sattlelite A305 wont project to LCD
I just purchased a A305 and when you toggle F5 and select LCD and CRt or just LCD there is no signal to projector?? any suggestions
  • Toshiba Master
  • 13,433 Answers
Hello again, you havent written a review yet, if you have a minute click on the my profile link on the right top cornet of the page, then scroll down your profile untill you see our chat session and click on write a review. Thank you for your time and if you still have any problems feel free to contact me with the ask me button.
Posted on Jun 19, 2008
  • 4,234 Answers
Two things to look for:
1) Make sure that the resolution is one that the projector can understand.
2) make sure that the projector is looking at the correct input.
The laptop should have either the external monitor enabled alone or both the laptop screen and monitor enabled.
Keep us posted.
Dan
Have a Gateway Notebook KAV-60 with a broken screen. Trying to connect to an external monitor without any prompts or commands, as I can't see the screen. With an Acer Netbook I just plugged in the
Make sure the vga cable is in tight on the kav-60 and the external monitor.
Try the keystrokes to toggle the display. Normally you would Press and Hold the FN function key located at the lower left on the keyboard then hit the key F1 thru F12 that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display. The display toggles in three stages ( laptop only, external only or both laptop and external).
Apr 29, 2012 | Gateway Computers & Internet
Where is my function key to Select Output to my TV
Fn + F5 will toggle through all the available settings, re: internal lcd, internal lcd + external, external only, internal lcd + external as extended desktop etc.
Jun 28, 2010 | Toshiba Satellite A105 Notebook
When i hook my L455 to my sony hdtv the screen on the lap top turns black and the tv only says no signal in the pc mode. do i have to change some settings on my laptop
TV:- probably has a PC input - which is a VGA connector looks like this http://upload.wikimedia.org/wikipedia/commons/9/92/SVGA_port.jpg and then you select PC input on the TV to display whats connected to that port Laptop: - Now on the laptop, you will need to select the VGA output to work - thee will be a picture of a screen on one of the F keys at the top of the keyboard, F4, F5 normally on laptops, My Toshiba its F5 ---- (assuming F5) use the FN key and the F5 key together it will then toggle between the following <laptop only><laptop and VGA output><VGA output only>
If you are not using a VGA cable and are connecting by HDMI cable - then there will be a F key to toggle the HDMI output - and you will need to select HDMI on the TV - NOTE: if this has a blue ray player and you are playing a blueray DVD, theres is copyright to protection to only allow one screen to be used, so you will need to toggle the laptop F key to just output from HDMI
Mar 22, 2010 | Computers & Internet
I cant transfer my laptop screen to my pc monitor.. how i can transfer it???
Press Fn key + F5 once or twice. Usually Fn+F5 will toggle you between 3 options: internal LCD - Both internal & external - Enternal only. Wait a moment after changing the mode, as the monitor has to detect the signal and react to it.
Once you are on external only, you can change the screen resolution to better suit the external monitor's capabilities.
With the laptop and monitor active at the same time, both will operate at the same resolution.
Nov 20, 2009 | Acer Aspire 4530-5889 Notebook PC
Toshiba Satellite L25-S1194 attached to TV monitor can't get display on laptop at same time HELP!!
Connect your TV to the computer with an S-Video cable. Turn the TV on and choose the AV option (of your TV) to S-Video. It will tell you that there is no signal on the TV.Press the Fn key on the keyboard. While keeping that key pressed, press the F5 key. A small rectangle appears on the screen showing different connection possibilities (LCD, LCD +TV, LCD+CRT, TV only, CRT only). You can cycle through the options by pressing F5 repeatedly. You select the output option (TV + LCD).Release the keys . You will then have your two screens.
Note: I assumed you connect the TV through the S-Video. If your TV can be used as a monitor (it has a VGA adaptor), then with the F5 key select option LCD and CRT
Hope it helps
Aug 28, 2009 | Toshiba Computers & Internet
Fn combination keys for external monitor
Key Combination Functionality
Fn+F3 Reduce speaker volume
Fn+F4 Increase speaker volume
Fn+F5 Switches display: LCD, CRT, and LCD/CRT simultaneous
Fn+F6 Increase LCD brightness
Fn+F7 Decrease LCD brightness
Fn+F10 Toggles battery warning off and on
Fn+F11 Switches the LCD panel off and on
Fn+F12 Places the computer into Hibernate mode
May 22, 2009 | Compaq Keyboard
Computer turns on w power but monitor wont turn on
Try circling through displays Use FN + F5 as per user MANUAL INSTRUCTION ON PAGE 5-4
"Pressing FN + F5 changes the active display"
Jan 24, 2009 | Toshiba Satellite A305-S6853 Notebook
Acer aspire 3680
Display Toggle - <Fn> + <F5> will toggle from external monitor
Screen Blank - <Fn> + <F6> will turn the LCD off
hope that helps.
Jan 27, 2008 | Acer Aspire 3680 Laptop
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Toshiba Sattelite A105-S2071 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
