Question about RIM BlackBerry Pearl 8100
Media card i took the media card out of my blackberry and insterd it into another phone but when i put it back in my phone it doesnt read my card. it tells me that it contains errors and that i have to use a disk error cd to check the utility on my computer. But i dont have the disk error cd. How can i fix that? I dont wanna have to get rid of my memory.
    Problem Solver:
  • 6 Answers
Jus put ur card in card reader and format it it will start working
Posted on Jun 23, 2008
My blackberry 9900 won't read media card
Will it read any card? if it will read another card just not "yours" or the one you want it to read then the card is either faulty, needs to be reformatted, or is a too high capacity for your phone.(some phones wont accept high capacity memory cards) How ever if your phone will not read any card it means you phone memory card reader is faulty or has poor or non existence connection to the proper points on the phone circuit board- in that event if it will not matter what the cause may be, you cant fix it- take it for repair--Good Luck.
Jan 27, 2013 | RIM BlackBerry Bold 9900 Cell Phone
Im having a problem with my Micro SD 4gb Memory card for my Samsung Intensity phone. I put it in my computer & it read just fine then I took it out & put it back in when the file for it wasnt...
simple rule....when a device / drive is reading a media (say CD disk, pen drive, memory card etc) never pull it out....
it spoils the media....
frequent changes to any media device will hamper it's quality and efficiency.....
the recent micro cards are so sensitive that even a small mis handling / hard handling will make it corrupt.....
the best option...buy another one...
reg
Suresh
Apr 28, 2011 | Computers & Internet
How do I transfer pictures from my blackberry device to the media card?
It's recommended to buy a microSD card to store your media files on, so you don't run out of memory on your device.
Depending on what OS your BlackBerry is tells you what size microSD card you can buy. You can check under Options ' About (will be listed as v4.xx.xxx). Look at the chart at the following link to see what size you can obtain -http://www.blackberry.com/btsc/KB05461
On the BlackBerry go into Options ' Media Card. Recommended media settings are as follows:
Media Card support : ON
Encryption Mode : NONE
Mass Storage Support : ON
Auto Enable Mass Storage Mode When Connected : YES
Mass Storage mode allows your BlackBerry to act as an extra drive when connected to your PC. So it will show up as an extra drive letter in Windows Explorer. So you can just drag/drop media files onto your media card and vice versa.
Or if you use ITunes, you can you the Media Sync to synchronize with the device. Read up about that here:http://na.blackberry.com/eng/devices/features/media/mediasync.jsp#tab_tab_overview
Oct 10, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Screen doesnt work
if you have a screwdriver, you can open the phone up and check if it is still dry or wet and also look to see if there are any burnout marks (greeny-blue or white).air it for an hour or few and put it back together. try again. is it pos 5 or pos 6 bit. or is it tork 5 or 6, at jay=car or dicks or bunnings if you don't need advice on it.
May 30, 2009 | Lands Phones
SanDisk 2GB memory card
format the mem card through your computer instead maybe, it works best if u have a usb reader that the sd card slot in then jus plug it in. if it dont automatically show up on pc go to 'my computer' in the menu and it should b found there prob as removable drive, once in it right click mouse and should b an option to format sd card, hope this helps.
Apr 10, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Phone cannot read or doesn't recognize media card
It need to be unlocked, enter blackberrymep.com to get MEP2 code (blackberry sim unlock code) .
Apr 02, 2009 | RIM BlackBerry Bold Smartphone
Can't open data stored on media card
Connect the BlackBerry to your computer.
Open My Computer, and open Properties of the drive.
What does it show under File System?
The BlackBerry cannot read NTFS, so make sure that it is not an NTFS file system. if it is, move your files off the card, and format it as FAT, then put the files back on the card after the format.
Otherwise, without the BlackBerry connected to the computer, go to Options (or Setting > Options, depending on your Theme),
Then opem Media Card, or Memory (depending on your Theme and software version).
What does it say about the card? Does it say that it is connected, or that there is no card?
Jan 21, 2009 | RIM BlackBerry Pearl 8100
Media card insert
you need to format the card. Go to options, scroll down to "media card". Click on this, when it opens, make sure media card support is "on", .......make sure Mass storage support is "on" Then click on "Menu" which brings up the option to "Format card" Then cliuck on this option and it should be OK,
Jan 07, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
An Error from a smart phone from an SD micro card
Try
1. by putting it again into palm top
2. try Formating the memory card ( if you fail to even after format your Mcard has a internal problem )
PLEASE RATE ME ( FIXYA )..................................
May 23, 2008 | Electronics - Others
RIM BlackBerry  Pearl  8100 Logo
105 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
