I'm replacing a Linksys BEFW11S4 router with a newer Linksys model WRT160N. What do I need to do to uninstall the old one, if anything. Do I need to delete all my current connections? Thanks, Mike
  • brian c
    brian c May 11, 2010
    Actually, jjmcgaffey, the question I asked is completely valid.
    Just because they are staying in the same brand router is completely irrelevant.
    If they are using DSL, they will need to enter the correct login information into the routers configuration menus for the modem to connect to their ISP.
    Cable service "should" work without any changes.
    They also didn't mention if the old router was using any type of security features, whether it be WEP encryption or MAC filtered. Neither of these functions will automatically configure themselves.
    Please do your research before spewing your advice.
    Thanks.
  • brian c
    Are you using cable or DSL?
    Problem Solver:
  • 12 Answers
It should not require any changes - since you're going from Linksys to Linksys, the IP address of the router is the same (I believe). So shut down your computer (one with a wired connection to the router!), unplug the old router, unplug your modem, plug in the modem and wait until the lights settle down, plug in the new router and wait until the lights settle down, boot up your computer and wait until it's fully booted. Open a command prompt (Start Menu/Run/cmd) and type ipconfig /all - see if you have an IP address assigned in the range of 192.168.1.x . If so, open up a browser and see if you can access 192.168.1.1; it should demand a login, use your new router's default login (in the manual) and make the changes you want (including a new password!) - change the name of your wireless network, set up security, etc. As long as you make your SSID and security identical to what you had on the old router, it shouldn't require any configuration changes on the computers (though it may require a reboot to make them see the router properly after the changeover).
Posted on Jun 19, 2008
I've forgotten my security password for the wireless and want to allow another computer access. as i'm not very technical is it difficult to reset andstart again?i don't want to be without the...
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and configure it again.
To reconfigure your LinkSys, connect a PC to one of it'sEthernet ports, load a web browser, and go to the URLhttp://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." While newer models, both the default username and the default password are set to "admin."
Once you go past the login screen, you should be able to reconfigure the LinkSys router.
Here are some of LinkSys Router models along with its Default usernames:
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys WRT54G, BEFW11S4: admin
Linksys Comcast routers: comcast
All other Linksys routers: {none}
Here are some of LinkSys Router models along with its Default passwords:
Linksys Comcast routers: 1234
Linksys BEFW11S4: {none}
All other Linksys routers: admin
For those [none] username/password entries listed above, no name or password is required. Just skip or press the Enter/Return key when prompted for those settings.
Jul 18, 2011 | Zyxel (91-004-361002) Wireless Router
Need manuel for linksys model befw11s4 router
YOu can go to this link for manual guide:
http://www.scribd.com/doc/202195/Linksys-BEFW11S4-WirelessB-CableDSL-Router-Manual
or
http://www.retrevo.com/support/Linksys-BEFW11S4-Wireless-Routers-manual/id/420ag807/t/2/
>you can download the manual free
May 22, 2011 | Computers & Internet
Linksys WRT160N Connection Issues.
Sadly, this router has horrible reviews and is known for this problem:
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16833124277
Can you return it for another model?
Can you getLinksys to replace it?
the best one is the LINKSYS WRT54GL, but if you are stuck with the one you have...
If you have tried all these things and you are very brave (or don't care if you need to buy another router) why not try flashing it with an after market O/S?
1) http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
2) http://www.dd-wrt.com/phpBB2/viewtopic.php?t=32576&highlight=wrt160n
Oct 13, 2009 | Linksys WRT160N Wireless Router
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Apr 09, 2009 | Linksys WRT160N Wireless Router
Have wireless connection, but can't get online
Linksys wireless router has many bugs: connection issues like no connection or constantly having to reset the router. It isn't compatible with many network adapters. Hope this helps!
Jan 25, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys befw11s4 wireless-b broadband problem
Yes you can upgraded that, you ne3ed to go to http://linksys.com/download and then select the model number of your router and download the firmware and install it, there is also steps on how you upgrade it on the web site
Sep 26, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Need to install wireless router model BEFW11S4 I don't have the dics
http://www.opendrivers.com/driver/228387/linksys-befw11s4-v4-wireless-b-broadband-router-firmware-1.52.02-free-download.html
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859878881&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7888141396B02
go to either one of the links. 2nd recommended.
Aug 11, 2008 | Computers & Internet
Linksys BEFW11S4-RM 4 port wireless router
This is an old router. Look at the power light. You must have a STEADY power light. RESET the BEFW11s4 by pushing the reset button for 30seconds. Unplug the power of the BEFW11s4 for 30 seconds. Connect pc to port 2 or 3. pc should get an ip of 192.168.1.x. If you are getting this ip that means that the pc is already detecting the router.
Good Day
Mar 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I lost my lynksis befw11s4 router star up disc what can i do
There are 5 versions of this model. The drivers for your LinkSys BEFW11S4 Router are available here. You have to select which version you have and can be found at the sticker underneath the router.
Good luck and kind regards.
Oct 25, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
