How to install samsung pedestal - Washing Machines
  • Anonymous Apr 25, 2009
    We had the same problem. Easy fix. We called the store where we bought the pair and the salesman was very helpful. He said in transit/delivery the boxes can be tipped and the instructions sometimes fall at the back of the drawer. Remove the bolts on the side of the drawer(on the metal bracket) and slide the drawer out. There will be a bag sitting there with instructions and bolts for attaching the pedestal.
How to install a pedestal
Posted on Mar 15, 2011
Fix pedestal for samsung 740BF
you can buy a wall mount for under 12 bucks. Or alternately you can buy an VESA 100 mm compatible stand for about 30 bucks
There're are out there lots of solutions for LCD, arms for mounting in desk, wall or poles.
Mar 22, 2014 | Samsung Computers & Internet
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Samsung Dryer keeps tripping the circuit breakers
The "professional installer" likely set the pedestal on top of the power cord and damaged it, or the dryer duct has been pinched off causing the dryer to overheat.
Jun 13, 2010 | Samsung DV448AGE Gas Dryer
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Samsung pedestals
Howdy,
So we had a similar problem. I actually went to a Sears Outlet here in San Diego where a tech gave me the bolts for free! But......the pedestals are still not compatible. I think Samsung built this discrepancy on purpose, just as other manufacturers do, because it makes them money. No cutting corners and buying previous year's stuff at a discount. BTW, I did verify the incompatibility with Samsung...
Good luck!!
Sep 29, 2008 | Washing Machines
Samsung WF 338 washer
Hello.
These are usually shipped with a number of "shipping bolts" to lock the drum in position during transit. If they are not removed when it is installed, then the washer will behave exactly as you describe. Check the manual or look for a sticker on the back or the washer showing which bolts to remove,
-ellie
Jun 26, 2008 | Washing Machines
Washing Machines Logo
2,568 people viewed this question
Top Washing Machines Experts
