Question about Canon PIXMA iP1800 InkJet Photo Printer
Black Printer cartridge
Hi can you help me please.
I have lost my booklets on how to help when you have to replace printer cartdrige. my problem is i have used up black ink cartridge and the colour one, i have purchased a new black one and have inserted but i have not replaced the colour one and as it is empty i have taken it out of the printer. i am trying to print off my word document and want it in black ink, why does it keep popping up colour cartridge is low. I only want to print with black????????
Help asap
Sharon.
  • 3gogirl Jun 24, 2008
    Thanks mate i will have to do that then, i cant believe i cant print just in black its so annoying, cherrs for your help.
Black cartride error
Posted on Jun 25, 2008
    Scholar:
  • 187 Answers
It will tell you the colour is low, regardless of the format in which you are printing. I don't believe Canon provide a way for you to disable this for their printer range, so you'll need to put in the new colour cartridge to get rid of this error. (you should however, be able to print whilst receiving this message)
Posted on Jun 24, 2008
I replaced a black cartdridge epson sx 510w, but the printer doesn't recognized it?
I would recommend the following:
  • Remove the cartridge from the printer.
  • Turn the printer off.
  • Wait 30-60 seconds.
  • Turn the printer back on.
  • Reinstall the ink cartridge.
If the printer still doesn't recognise the cartridge it is likely to be faulty. In which case I would recommend seeking a replacement from wherever it was purchased.
Feb 27, 2013 | Epson Office Equipment & Supplies
Dcp j125 wont recognize the ink cartdrige
Yes, it can be VERY frustrating. I would start with cleaning off contacts on the cartridge and on the printer where the cartridge plugs in. ... If it is a refurbished cartridge (or refilled) it's sensor internally could just be worn out. If you have tried multiple cartridges that are new or known good, it is possible your printer has a hardware problem too. ... If you know someone else with the same model of printer, try the cart's in the other printer to see if they are sensed good.
Apr 09, 2012 | Office Equipment & Supplies
My black cartridge was running low but was still printing. Then I got the Cartridge error message and to consult my user guide. I have misplaced the booklet. I replaced the black ink cartridge and...
Welcome to Fixya. If you lost the user guide on how to fix the error perhaps the link below will help you out your problem. It contains solution on how to fix cartridge error and the proper way to replace cartridge.
Dell AIO 948 Troubleshooting
Thanks
Jun 17, 2011 | Dell 948 All-In-One InkJet Printer
Printer wouldn't work - said cartridge jammed - I took coloured one out - can't now get it back and the other one will not go into middle of printer for me to but the one back into position
Hi Good daY!!! Check your printer if there is something that block your print head. after that turn off your printer and then move the cartridge into the center and then remove the ink cartdriges. after that turn on your printer without the ink cartridges, now your printer will recognize that your ink cartdriges is missing after that insert the ink (insert it properly) and then see if your printer would work now.
Thank you for using FixYa
Please accept if my solution helps you
Nov 14, 2010 | Dell 924 All-in-One InkJet Printer
My printer is blinking E5.
hi...e5 = you printer cannot detect your cartridge...try to clean the cartridge chipset using a clean tissu....or make sure you using a cartdrige no 40,41.....but the best solution is change the new cartdrige....
Apr 17, 2010 | Canon PIXMA MP160 All-In-One Printer
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
Mar 08, 2010 | Lexmark P6350 All-In-One InkJet Printer
I refilled the black cartdrige and now the printer gives me a message like the cartdrige is incompatible.
Sounds like the electronics on your cartridge are bad. You need to either get a brand new cartridge or another refilled cartridge.
Feb 04, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Where is the ink cartridge? I need to replace the black ink and lost the booklet. Can you please help me?
Here is a link to your printer manual.
Just choose the operating system and download your manual.
Hope this helps.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13800
Nov 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My printer is not printing..page comes out blank. inside, all the lights are flashing on the ink cartridges...any ideas what's wrong? thanks
this message means that the cartdriges are empty...
if you have bought new cardridges and lights still flash then the printer just dont recognize them right.
possible cause 1:
dirty cartdrige (or printhead) chip contacts > clean them with alcohol and cotton (switch printer off first).
see the chips in this photo:
https://secure.datatekusa.com/images/canon%20PGI5.CLI8%20refillable%20cartridge.jpg
possible cause 2:
bad printer controller: the chip in the printer that communicates with the cartdriges is gone mad... take the printer to service...
all the above are valid assuming you bought original cartdriges if not then do so...
Sep 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
111 people viewed this question
old marine
old marine
