Question about Panasonic Lumix DMC-FZ5 Digital Camera
Backlight I am having a few problems, but I'll bet they are all related: 1. backlight icon stays on 2. white lines across picture on playback or: 3. often picture will look b/w; very sharp contrasts. 4. All looks ok when taking picture; problems start when reviewing or putting on computer. I have used "reset" with no help.
  • 95 Answers
Its sounds like the camera is over exposed and the shutter is not functionaling correctly. qualified tech to look at camera.
Posted on Jun 25, 2008
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Sony dcr-trv120 playback
the problem is with the video head. either it's dirty or broken. if cleaning tape is not solving the problem then i fear you have to get the head changed. an expensive repair.
Jan 18, 2008 | Video Cameras
Faint white line observed on print
nope, the TONER OR INK CARTRIGE is running out in tat area, so you have to check it so that there is a new one. hope this helps. :)
Dec 08, 2007 | Minolta magicolor 2350 Laser Printer
Picture faded with white broken lines
Hi, the problems you describe are indeed related... the cable that carries the data from the lower section (mainboard) to the top screen is also responsible for the sound and the speakers are connected to this cable near the top LCD screen. It sounds like the cable has become damaged and will need replacing which unfortunatley means a new top screen due to the way the cable is connected to the screen. I come across this problem frequently and I charge customers £35 for a replacement screen and fitting.
Sep 01, 2007 | Nintendo DS Lite Console
White line across image
sounds like capacitor problems or a possible ccd problem or driver problem .Its time to send in the unit for an estiamate. Cont # is 1-800-NIKON-UX , 1-800-NIKON-US Good Luck
May 11, 2006 | Nikon Coolpix 5700 Digital Camera
Panasonic Lumix DMC-FZ5 Digital Camera Logo
134 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
