Question about Delphi NAV200 GPS Receiver
New route in the left hand lower corner of my delphi nav unit the gps turn by turn directions box keep showing NEW ROUTE and the voice command no longer speaks anymore since this has started. Can you please help with this?
  • 1 more comment
  • zuck04 Jul 13, 2008
    same problem here. Do you have a step by step, detailed correction for me that does not understand how to reformat the card? thank you
  • fennessy Jul 28, 2008
    can I get a new sd card without going through all that stuff? I am not a tehno.!
  • Anonymous Oct 02, 2008
    I had the same problem. Instead of whiping out the whole flash card and formatting all that fun stuff... I just opened the files. The ini file on the disk contains a location to the map files. I should look for the exact names but all you have to do is copy over that line of code from the disk file into the smart card ini file. Its much easier and doesn't whipe out all your current locations. Now the voice comes on and everything works great.
From Delphi tech support:
NAV200 SD Card Reformat
Problem:
Customer reports that the NAV200 has lost its voice prompts and/or constantly reads NEW ROUTE.
Solution:
Reformat SD card from FAT-32 to FAT. And replace files on SD card with back up files from DVD-ROM.
Reason for Problem:
The navlib.ini file located in the navigation files (in mnav) is missing from the SD card. It is located in mnav in the back up files found on the DVD-ROM
Posted on Jul 09, 2008
How can I start using my new Nuvi 2569 sat nav?
Step Description Step 1:
Warm Up If possible, let the GPS warm up for a few minutes once turned on. This allows the GPS to acquire its current position via satellite. Step 2:
Determine Preferences Choose day or night colors to display a suitable screen for the time of day. Step 3:
Adjust Volume Adjust the volume so the device can be heard over traffic noise. Step 4:
Enter Address Through the onscreen navigation option, enter the street address for the destination. Step 5:
Verify Route Check the listed route for accuracy, adjusting as needed. Step 6:
Follow Directions Follow the directions given by the GPS device to reach your destination. Some models, especially in-vehicle navigation, offer voice directions. Step 7:
Turn Off Once you've reached your destination, turn off the GPS device to save its battery charge. Step 8:
Store Device Store the GPS device out of sight if possible, or take it with you to prevent theft.
Mar 27, 2016 | GPS
My Gamin Nuvi can't unlock maps
Use a Garmin 1450
The Garmin Nuvi 1450 can be used while driving or walking.
While driving, use the Nuvi 1450 to create a route to your destination and get step-by-step directions, to hear the names of upcoming streets, to tell you when to change lanes and to find out the speed limits on unfamiliar streets.
As a pedestrian, you can have the Nuvi 1450 create a route for you that uses a mixture of walking and public transportation, such as the subway or bus system, if you have purchased cityXplorer maps for that area.
Tap "Where to?" to set up a route. The "Where to?" icon is a large magnifying glass.
Tap "Addresses." The available categories are address, points of interest, go home, recently found, favorites and intersections.
Input the name of the state or county, if it is out of town.
Then tap "Spell city." Spell out the name of the city using the pop up keyboard.
Press "Done."
Enter the address number and press "Done."
Then enter the street name and press "Done."
The "Go" screen opens automatically.
Tap the green "Go" button. The Nuvi 1450 will now calculate a route to the address.
Follow the voice prompts and map highlight to your destination.
Navigate Using Coordinates
Tap "Where to?" and then tap "Coordinates."
Tap the coordinate you want to adjust/input a new coordinate.
Tap "Format" to choose the right coordinate format for the map you are using.
Enter the coordinates. Tap "Next."
Tap the green "Go" button to calculate a route.
Use the Map Page
Navigate to your destination by following the voice prompts, highlighted route on the map and directions located at the top of the map screen.
Tap the "turn" icon located in the upper left corner of the screen to see the next turn. It may have a turning or straight arrow and the number of miles until the turn. Tap the bar across the top with the next direction listed on it to see a list of all directions.
Tap the plus or minus signs on the right side of the screen to zoom in or out.
Press the spinning arrow in the lower left corner of the screen to return to the main menu.
Tap the "car" icon traveling along the highlighted route to enter the "Where Am I?" screen and get your exact location, coordinates and nearby emergency services.
Hope this helps
Oct 29, 2012 | Garmin Nuvi 1450 GPS Standard Red LED Wall...
Tomtomworks but no sound
There could be 2 reasons: 1: Sound is muted. Solution: Tap on the screen. Tap change preferences. If you see a green square with "Turn on sound", tap on it. If it is a red Turn off sound, try the next solution.
2. Sound is kept very low. Solution: There is a volume slider bar. Generally it should be on the bottom left hand corner. It you touch the area where "no route planned " is shown, the volume bar pops out. Rub/Slide your finger slowly from left to right. This will increase the volume.
Jul 20, 2010 | Tomtom ONE XL GPS
Seems confused , uses the longest possible route, blurts out wrong directions which contradict previous directions, shuts down after 1.5 hours without an external power source. The unit is only about 2...
Each time you arrive at a destination, check the main menu. If [Stop] is still showing, push that before setting up a new route.
I had your symptoms once ... Had set up a route, and pushed detour several times. From that point on directions were inconsistent, until completely clearing the route, and starting over. Have never had the problem since.
If you live in a hot climate, or if the sun gets direct access to your GPS, the heat through windshield might damage your unit. Excess heat or cold will lower your battery life.
Jun 06, 2010 | Garmin nuvi 650 GPS Receiver
Lost Memory Card for Route66 Sat Nav
Get the SD card for any comuter store, and after you have to install the nav software on it, which for some information regarding the unit I will sell it to you for a rezonable price
Aug 19, 2009 | Route 66 Mobile 7 GPS Receiver
Why is it taking me in the wrong direction
you will need to update your GPS device , go to garmin's website and look for the new maps for your device.
Aug 17, 2009 | Garmin nuvi 200W GPS Receiver
Stop a nav route
Once you pick your new destination, the unit will ask if you want to delete the previous destination. If you just want to delete the route, hit the menu button, go to destination, and it's the bottom right selection.
Mar 25, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
WAAS
sounds like the problem is with the pilot. You may be expecting too much from nav mode you should check the antenna connector on the WAAS issue
on VX2, are you marking a good bottom on the sonar screen, but have no digital overlaid? never seen it, must be a BB thing
May 04, 2008 | Furuno GP32 GPS Receiver
No signal on new GPS Delphi
Return it to the store. I got one for Christmas and right out of the box it always said "New Route" and would never give me directions. The one I exchanged it for works perfectly.
Dec 26, 2007 | Delphi NAV200 GPS Receiver
Delphi NAV200 GPS Receiver Logo
217 people viewed this question
Top Delphi GPS Experts
kenneth njonjo
Are you a Delphi GPS Expert? Answer questions, earn points and help others
