Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
SOURCE: My kenmore built in dishwasher is leaking out the front
change the door gasket. also check to see if the wall hasn't "sprung out" of position this will always cause leaks if the side walls aren't supported.
SOURCE: I am getting water leaking through the diswasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dfkhdlh
leak in front on left side
