Question about Brother MFC 240C All-In-One InkJet Printer
Brother FAx My fax machine will not let call through to the rest of the house, how do I stop the fax from taking all the calls?
    Problem Solver:
  • 5 Answers
Posted on Jun 19, 2008
I cannot send faxes or make copies with my Brother intellifax 1270e. When the paper gets to the read point sensor it stops and says "press stop button" . The machine will receive fine and print...
Cleaning the Scanner
Before cleaning, unplug the power cord for safety. Clean the white roller and the glass
strip under the roller with isopropyl alcohol on a lint-free cloth. You'll need to lift the
two release levers to release the white roller; be sure to lock them in place when you're
During cleaning, I recommend you unplug the power cord for safety.
Brother fax-back system (USA Only)
Brother Customer Service has installed an easy-to-use fax-back system, so you can get
instant answers to common technical questions and product information for all Brother
products. This system is available 24 hours a day, 7 days a week. You can use the
system to send faxes to any fax machine, not just the one from which you are calling.
If you can't resolve difficulty with your fax machine using this manual, call our
fax-back system, and follow the voice prompts to receive faxed instructions about
using the system, and an index of fax-back subjects.
The Brother fax-back system number has been preprogrammed on One Touch key
Dec 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
Fax issues - Brother 1020e
Sounds like your phone cord is plugged into the "tel" or "phone" port on the back of the fax. It should be plugged into the "line" port.
Oct 25, 2009 | Brother FAX-1020e Plain Paper Thermal...
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Apr 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Program Fax-930 brother machine so it answs fax call on 6 rings
Here is the users manual for that;
Mar 16, 2009 | Brother FAX 930 All-In-One Thermal Printer
Need to reprint previous fax.
you can't. check the journal for the last receive transaction fax number. send a request for re-transmit.
Mar 11, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
May 27, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Fax machine and ans machine coming on together
Fax machines normally take priority over answering machines.
there should be in your menu and fax settup a place to select fax/ans to allow the machine to know it has another device on it.
I suspect that your fax is set up in fax mode only. Somehow it got changed, or changed itself.
Check for the setting on your machine that allows you to operate both. You may have to call brother for the right setup also.
Its find their support number there. Good luck,
Mar 19, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother MFC 240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Jim Keysor
