Question about Canon ZR800 Mini DV Digital Camcorder
Camcorder hi,yes i plug in my camcorder to the outlet and their is no indicator,nothing happens
  • Canon Master
  • 2,794 Answers
You need a video capture program to detect it.
Do you have one available to use?
Posted on Jun 22, 2008
This is the first time I'm using my Mr Coffee Frappe maker and after plugging in the machine and pushing the power button, nothing happens. Should the red light come on right away?
yes you should get some kind of power indicated that power is on the machine i would first check the circuit breaker and then assure that you have power coming out of the outlet after which you could then use a multimeter to folow where you do have power going to sometimes it could also be a bad switch on the unit itself but first assure where you do have power going to and any further questions message me back Thanks Rick
May 19, 2011 | Vacuums
My linksys wireless g router will not power up,n yes I have plugged it in but no lights are comin up on the router.it was fine this mornin but turned the the plug of as I left the house come home turned...
Try to connect the router to a different outlet and try to turn it back on, if nothing happens, theres a possibility that there is something wrong with the routers power supply.
Hope this will help... Your response is very much appreciated...
Jan 26, 2011 | Linksys Computers & Internet
My Flipshare video camera will not turn on. When I try to power it up on my computer or with the power cord, nothing happens. No light goes on, no nothing. Pleas help!
Hi d_cockerham,
You should try resetting your Ultra HD Flip Camcorder. Unfortunaately the support knowledgebase does not list the proceedure but I managed to get an email from them on how to proceed.
The steps to reset/resolve an issue where your UltraHD will NOT turn "On" is as follows:
  1. Remove the battery pack from the camcorder.
  2. Connect the camcorder to a powered USB port on your computer.
  3. When the "Connected" indicator comes on, insert the battery pack into the camcorder.
  4. Safe eject your camcorder from your computer.
  5. Reconnect your camcorder to your computer.
  6. The battery pack should now begin to charge within the camcorder
Hope this helps anyone else who encountered similar problems.
Jan 08, 2011 | Pure Digital Flip Video Ultra Camcorder
ZR100 will not trun on
How long have let the camcorder sit still before using again? It seems that you were using it then the battery was out of charge, then you tried to charge it, but nothing happend. Is that your problem?
Jul 25, 2010 | Canon ZR100 Mini DV Digital Camcorder
When i connect my camcorder through the firewire
Hello my friend, yes had same problem, I had hair when it happened to me, now bald hi hi, but you need to go into the PC Control panal, go to System settings, look down a long list eg Sound, Drives, Mouse, etc look at Cameras, if your camera is in the list highlight it, and delete driver with clicking you mouse on it, come out of control panal on PC, REMOVE ALL camera cables from PC, turn off your PC in normal way.
Now when your PC is OFF plug your fire-wire cable in camera, then to the PC, turn camera on, and THEN turn your PC on (MUST BE LAST THING YOU DO) then once your PC is fully rebooted and you are in windows your camera is seen all done.
Take care, all the best.
from
David
Jun 21, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
I can't upload my pictures onto my computer from my camera!!
You need to update the driver from XP to Vista for the program to correctly recognise your camera
Aug 31, 2009 | Canon PowerShot A590 IS Digital Camera
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Dimension 3000 Power up problems
Sounds like you have a bad power supply. If your computer is plugged in and you turn it on and nothing happens then replace your power supply and all will be well. And yes the monitor needs to be plugged into a outlet and also the back of the computer to work.
IF this has helped please rate
Feb 12, 2009 | Dell Dimension 3000 PC Desktop
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Canon ZR800 Mini DV Digital Camcorder Logo
32 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Chris Phillips
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
