Connection how to connect Behringer FBQ2496 to Behringer Xenyx 1204 to avoid feedback?
  • 4,234 Answers
There are 2 ways to have an EQ in the system. If the mixer (1204) has inserts for the mains, you can use a set of insert cables to connect the EQ. If not, connect the Output of the mixer to the Input of the EQ and the Output of the EQ to the Input of the Amp.
The insert cables will allow you to electrically connect the EQ as described above only using a single set of cables. These cables are 1/4" balanced or stereo at one end (Tip-Ring-Sleeve) and dual XLR at the other. You will need 2 insert cables, one for right and one for left.
Hope this helps,
dan
Posted on Jun 19, 2008
How do I get driver updates to connect with pre sonus software
Not sure what your issue is, as long as you have the ASIO drivers installed you'll be able to get a decent copy of the main mix into and out of presonus. Even if not the standard windows sound drivers will recognise it as an external sound card and you can map this into / out of presonus so you don't actually need ANY drivers other than standard windows ones. If you were hoping to get access to the individual channels to do the mix in presonus forget it, this is not what what your mixer is designed for, get an X32 or other professional mixer.
Mar 15, 2016 | Behringer XENyX 1204 XENyX 1204 12 Channel...
I need driver update to connect with pre sonus artist one software
If you use the Behringer ASIO drivers (available from their web site) it will connect just fine, you should also be able to use the sound card drivers that came with the computer as they should pick up on the mixer (assuming it is a USB version) but you do not say if you have a Mac, PC or what operating system you are running so it is impossible to be precise
What causes my cd/tape input doesn't work anymore.
Make sure that the cable going to the left and right inputs is OK. Try another cable or test with a different recorder.
Oct 01, 2014 | Behringer XENyX 1204 XENyX 1204 12 Channel...
Factory reset Behringer FBQ2496
After my FBQ 2496 began to go "wild", it finally went blank with a ticking sound. I tried pressing and holding the "Reset" and "Bypass" buttons, simultaneously during power on. It worked after 3 or 4 tries.
Feb 24, 2014 | Behringer USA FBQ2496 Ultra Fast 24 Bit 96...
Owners manual for Behringer xenyx 1204 USB
Behringer has the documentation for the Xenyx X1204 USB Mixer on the product page: http://www.behringer.com/EN/Products/X1204USB.aspx . See the drop-down menu labeled Documentation on the left side of the page; it's below the list of stores that sell the unit. The owner's manual is at the bottom of the list in that menu.
The file is a PDF so you will need Adobe Reader or a similar program to display the 3.1 MB file.
I hope this helps.
Oct 24, 2012 | Behringer XENYX X1204USB/1204 USB...
What is the best way to connect an external EQ or Feedback Destroyer unit to a Behringer PMP3000
Get an "insert snake" which splits each of two TRS plugs into TWO TS plugs.
Plug the TRS ends into the MAIN INSERT jacks and each of the "TIP" plugs at the other end into inpout jacks of the destroyer. Plug the "RING" plugs into the output jacks of the destroyer. You will need a snake with at least two sets of splits. I use a Behringer PROCOM compressor. For those the TRS plugs go into the channel insert jacks and the tips and ring plugs go to the in and out of each channel of the compressor respectively.
Jan 11, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How to connect PA mixer with built-in amp to feedbk dstryr unit?
The feedback unit should be connected between the pre-amp section and the power amp section. As you descrubed the ST-out and P.Amp IN are the ones to use.
Dan
Jan 22, 2009 | Audio Players & Recorders
Unit behringer xenyx 1204 fx does not work
i'm trying to find the circuit diagram for a xenyx 1204 mixer
Nov 08, 2008 | Behringer EUROPOWER EP2500 Amplifier
254 people viewed this question
 Grubhead
Grubhead
