Doesn't work! This is a plug and play device. I plug it in and the "Safely Remove Hardware" pops up for a second, but then disappears. I can't find the card anywhere on the computer, not even on the Device Manager. I have a Vista computer [which I think is the problem] but the light on the reader is lit up the whole time it's plugged in, so it's not like it doens't have power. I know on this particular product it says that you need XP or a few others, but I have another post about a different product that reads Compact Flash cards made by SanDisk, and that doesn't wrok either. It didn't give any specs if it would be compatible with Vista. I would really like a solution to these problems! I may have to return these products otherwise.
  • Anonymous Jun 23, 2008
    For some reason it's not reading the card i can see the icon but it says insert disk ......
  • Anonymous Mar 13, 2009
    soyo fm--sy-slim20gb with 1.8" Toshiba 20GB drive
    This USB device will not work with Vista Business Edition and probably won't work with any version of Vista. I have used the device on Mac OS 10.5.6 with no problems.
    It will show up in the list of items to be removed, it will not show up in Explorer as a drive.
    If you need to use with a Vista system, take it back and buy something else.
    Problem Solver:
  • 5 Answers
VISTA DON'T RECOGNISE USB 1.1.
NEEDS TO BE 2.0
Posted on Jun 19, 2008
Sandisk cruzer 8gb suddenly not recognized when connected to my computer
1. Try the other USB slots to see it the board is ok. Most modern pcs have two slots in the front and two to four slots in the back, try them all.
2. Do you have another pc that you can plug it into? If it works on that one you may have driver problem or the board is bad on the other one.
3. Have you tried to plug other USB devices into the slot(s) to see if the port is ok?
I have the same one and have had to mess it sometimes. Have to right clicked the "Safely Remove Hardware" in the right corner of the task bar. Right click and then left click the Safely Remove Hardware. That will show you all USB devices loaded. If you see the Flash Drive, click it and when you see the next prompt to remove it wait a few seconds and then plug it back in. If that does not work, reboot and leave the Flash Drive plugged in and see if it loads when the pc fully is loaded.
4. Goto the Control Panel> System > Hardware > Device Manager. Look for your drive in the list of Disk Drives. Pick it and then pick the Action Menu and Scan for hardware changes. If the Flash Drive is working properly you should not see any errors. You should also be able to see the drive in explorer.
5. If you still do not see the Flash Drive in explorer but you do see it in Device Manager, right click it in Device Manger and unstall it and reboot and let windows search and reinstall the device drives.
Good luck and post back.
Jun 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How do i use my pny 2 gb chip?
You plug it into a USB port on your computer. It should be plug and play, meaning it just works, unless it came with extra software you need to run, but I doubt that. Once it is plugged into your computer, a window may pop up asking how you want to use it, or you can open My Computer, and it should be listed there. Double click on the name of it and it opens in a new window. You can now drag and drop files into and out of it. Also, if you are downloading files from the Internet, you can specify to save the files in this location and they go straight onto your pny. Once the file is saved onto it, you can remove it from the computer and take it with you to keep your files close, or use to to transfer files between computers. You may need to use a method of removing it from the computer that prevents damage to the data on it. This process involves clicking on a small icon in the system tray (by the clock in the bottom right hand corner) that looks like a green lower case "t" that says safely remove hardware. Click on this and then click on safely remove my "pny drive" and in a second you should get a message that says you may now safely remove your device. Unplug it and you are done!
Jul 21, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Device cannot work
Try cleaning your computer for spyware and viruses. Also try cleaning your registry out using a utility. Do your USB ports on the computer work with any other devices? Try using different USB ports and make sure theres no faults in you device list with the USB drivers. Let me know more info. What OS are you using. By unplugging it without safely removing is most dangerous to Flash memory but it's definitely possible to damage a hard drive by doing so. You might have corrupted your drive. Hope this helps.
Jul 25, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Can't seem to stop the device to safely remove hardware
if you know it is done transfering the data you should be able to remove it safely even if that message pops up.
Jun 13, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
The 'safely remove hardware' in my laptop keeps removing CD drive
it is there all the time on the taskbar- turn off your balloon prompts if it annoys you. The first thing I trun off in an xp install is the balloon prompts.
Apr 09, 2009 | IBM ThinkPad R52 Notebook
Can't get the software to detect the device
should be no compatibility problem.. not with xp... but you can check two different things... first check the "safely remove hardware" icon usually beside the time in the system tray. when you click on it once, it should say safely remove usb mass storage device drive *: (star representing drive letter), if no letter comes up then no drive letter is assigned and will have to go thru drive letter assignment.
the next thing would be in device manager in system properties... it should be recognized as usb mass storage device and disappear if you unplug your device. if not then the driver may need updating through microsoft
i would call Oly tech support so they can walk you thru the getting your device to work properly
Sep 15, 2008 | Olympus DS-2300 Digital Voice Recorder
Anko directory error when plugging into my computer
Microsoft error management for error 47 says
When the "safely remove hardware" icon is in the status bar (the by time) disconnet the mp3 player. After a few seconds connect it again. Then reboot the computer system. You will then be able to see the contents of the mp3 payer.
I tried and it works. Also it means the player could be removed without clicking on"safely remove hardware".
Jun 04, 2008 | American Anko MP-2GD MP3 Player
Wont turn on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Dec 25, 2007 | Mach Speed Trio DA-8033 MP3 Player
"Writing" prevents Safely Remove
Yeah - it keeps trying to transfer those songs to the player - it can't read directly from the location, but the processer knows its there; it doesn;t know what to do with it - so it';s stuck; delete the recordings, dude
May 28, 2007 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
