I can't eject my dvd rom. I push the button, it lights and nothing happens. What to do? (oh).... I need to get it open in order to reinstall the computer to its factory state.
    Sergeant:
  • 275 Answers
Posted on Jun 19, 2008
    Scholar:
  • 160 Answers
See that the power cable is connected Properly.
Change the power cable one by one and press the Open/close button of the DVD rom.
Let me know if your problem is solved and rate me as FIXYA!
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Cannot eject dvd
Good day,
If it's a dvd rom drive of a PC(personal computer), then get a long, strong thin material like a pin, at least of the length of your index finger. Around/beside the eject button on d dvd rom, you will see a small hole, like d size of a dvd rom led light, insert the thin material thru this hole until you "feel like you are pushing something inside the dvd rom". The dvd rom should open a bit, then you can open it completely to get your dvd.
I hope this helps. Thank you for using FixYa!!
Aug 29, 2012 | Dell (0F146) Internal DVD Drive
My cd rom tray will not eject and the light is
have you manually tried to eject the disc tray? There's a little hole on there somewhere, stick an unbent paperclip or safety pin in it and push until the tray starts to come out, then pull the tray out with your fingers.
Once you've done that, push the button to allow the tray to automatically retract.
Jul 22, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
CD-ROM not opening
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Oct 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
My cd/dvd drive is not working.
You could reinstall the CD/DVD drive software, but it sounds like the CD/DVD drive is faulty. You'll need to replace the drive.
Jun 12, 2009 | Averatec 1000 Notebook
When I press the bottin on the dvd burner to open the door, the green light comes on and i would hear the door try to open but no open.
yes frn this is happen due to the jam in the DVD rom. when you press the eject button put one pin in the hole that is just below the eject button. so that you can eject your DVD. or just hit the cd ROM slowly.
May 16, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Cd/dvd drive
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
Sep 19, 2008 | Dell Inspiron 710m Notebook
Cd stuck inside laptop
turn off the laptop and turn it on again as soon as you see the windows startup push eject button see if it open if not then the CD rom is jammed inside
Sep 16, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
