Question about Philips 60PP9352 60" Rear Projection Television
Philips 60PP935217 - Red Converge
Looks like I'm not the only one with this problem. My red convergence is way off, especially i the lower left to middle of the screen, and I'm not able to manually converge it. By searching online I've discovered that shopping channels are often the cause of this sort of thing due to the bright colors constantly displayed in those locations on the screen. I've also read that a burnt IC may be the culprit. Do any of you know which board I should be looking at, which IC on the particular board, and do you have the repair manual for this model. Also, is there a particular way to clean inside the unit without damaging the boards, and at the same time, a tune-up procedure for this TV? Sorry for sooo many questions, I just like to do things the right way.
    Habit-Forming:
  • 55 Answers
I had the same problem, had it professionally repaired. looked intense if you don't know what your doing. Be cautious. Try craigslist. I dont know where you live but I got a repair for $250. I know what he did though, msg me if you are planning on doing it yourself. I need a service manual bad. My colors are off, but not the same as yours. The STK392-120 are for your tv. I had them replaced and the picture was good, word of advice "dont touch the knobs hanging inside the unit that say RGB and Focus" LOL. :( I did, now I have green hair and blue grass. Good luck! the IC's are located in left rear part, you have to take out the whole curcuit board that has them on it. Just unplug all of the wires and unscrew the board from the base, makes much easier to work on.
Posted on Jun 24, 2008
  • 4,234 Answers
This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large and black, attached to a heat sink and are marked STKxxx.
Keep us posted on your progress.
Dan
Posted on Jun 19, 2008
Philips 55pp53217 i changed the IC's, change the fluid in the CRTs, picture looks so much better now with the exception of the red. which looks a bit blurry. When trying to converge in the menu, both the...
are the pitches set right if so then it might just be a focusing problem that i am not truly involved with i focus more on computers but i still fix tvs and other electronics
Jan 03, 2011 | Philips Televison & Video
Philips 43pp92 blue will not converge
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
BLUE CONVERGE NOT WORKING
most likely convergence IC's usually 2 of them
Aug 10, 2009 | Philips 60PP9202 60" Rear Projection...
Mitsubishi - cannot converge red
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 13, 2008 | Zenith R49W36 49" Rear Projection HDTV
Philips nr.43pp7445/69
I don't understand you language but I think you need both convergence amplifier IC's replaced. I hope this helps.
Aug 17, 2008 | Philips 60P8341 60" Rear Projection...
Magnavox rear projection
If the red converge will not line up, then there the convergence chips are actually bad - the repair will cost around $700 if you go through a Magnavox authorized service center. I would look at posts by Slinteriors in the Philips or Magnavox rear projection sections - he has some ideas on generic chips that might be had for cheaper.
Jul 06, 2008 | Toshiba 55H70 55" Rear Projection...
PHILIPS 43P8341 CONVERGENCE OF GREEN AND RED
Look for the STK ICs mounted on 2 big heatsinks.
I would suggest to replace both of them once you have the TV taken apart.
I think the part markings are STK392-040.
Let me know if you need further assistance.
Apr 29, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
466 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
