  • 1 more comment
  • bazzle Jun 19, 2008
    thanks for the reply, none of these....cleaned checked, not a 45. no good tried approved 15 still error message on black cartridge..cleaned changed colour cartridge argh
  • bazzle Jun 20, 2008
    Bob thank you for helping me. the comments on bottom of page limit to what one can say isincerley appreciate your help....Barrie
  • bazzle Jun 21, 2008
    Thanks Bob i did not realise the term i used was so bad, thank you for your help i will try the method got to go to work.Barrie
  • 137 Answers
FIrst make sure you are using a #15 HP cartridge, the #45 looks similar but will not work in the PSC 750. If the cartrdige is a #15 try cleaning the contacts as shown here.
If this does not resolve the issue check the warranty information. If the cartridge is an original HP (not a reman or refill) see the following for warranty information and if the cartridge is still in its two year warranty period return it to your dealer for a replacement.
If the cartrdige is a #15 reman you might find the following enlightening. In this case you will need to contact your dealer for a replacment.
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jun 19, 2008
  • Bob Headrick Jun 19, 2008
    Obviously I will never attempt to help you again.
    - Bob
  • Bob Headrick Jun 21, 2008
    For future reference, a rating of "Inappropriate" is something that would be assigned to a spammer or someone who was posting a response entirely inappropriate.
    The solution I gave you is correct for 95% of the cases I have seen, it appears you have a bad #15 cartridge. Did you try cleaning the cartridge contacts as shown in the link? This is different than using the toolbox or front panel to clean the nozzles. I would bet that a new HP #15 cartridge would solve your problem.
    - Bob Headrick, Microsoft MVP Printing/Imaging
Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Jul 28, 2011 | Lexmark X6570 InkJet Printer
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
Inserted correct hp cartridge however, display screen reports error incorrect colour cartridge installed? please help
The color cartridge you have is likely electronically damaged. I would recommend trying to exchange for a new one or get your money back.
Jan 19, 2010 | HP PSC 750 All-In-One InkJet Printer
Yes, you should return this cartridge to Office Depot. I own a cartridge refilling store and I've had a couple customers that buy original manufacturer cartridges that don't work in their machines. What I suspect is happening is that the manufacturers are making their printers stringently check the cartridges to make sure they are not refills and that this stringency is also occasionally kicking out their original cartridges.
Jul 26, 2009 | Lexmark X4530 InkJet Printer
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Error message Incorrect printer cartridge (but it is correct )How do i correct this error
I've never encountered a problem like yours on the HP78 cartridge or even the HP15. Have you tried cleaning the cartridge as well as the printer pin? The only time we had this problem with one of our customers, we cleaned the cartridge and the printer pins and the problem was gone. Let me know if this helps.
Jul 14, 2008 | HP PSC 750 All-In-One InkJet Printer
Printer error
you may need to do a clean heads and nozzles on that HP..try that first.
Apr 25, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Right cartridge incorrect
If it says to check the right cartridge (Black), replace it with a brand new one or one you know is good.
Walgreens will test and refill your cartridge for ~$10.00 (black).
I have heard of new OEM HP cartridges being bad.
The printer checks the cartridge level sensor and the electrical stuff.
Apr 21, 2008 | HP PSC 2110 Color Printer
209 people viewed this question
