Question about Yamaha RX-V661 Receiver
I have a new RX V661 7.1, shuts down when I turn it up.
Just hooked up my new receiver, keeps shutting down when I turn it up. I reconnected the wires to the back of the receiver, to make sure that there was not any wire touching or sticking out. Appears to be all clean in the back, but still shuts down. I have JBL in-wall speakers, have not pulled them out yet to check, but don't think that the connections at the speaker end is the issue. What can I do?
  • 1 more comment
  • Rob H Jun 19, 2008
    I would not say a lot of volume, the speakers are in my basement. At the point it kicks off, you can just start to hear it up stairs, so not too loud. The receiver reads check speaker wires, which I have done, and do not see any issues with the connections to the back.
  • Rob H Jun 20, 2008
    Thanks, got it fixed last night. I pulled all the wires out of the back, and replaced one at a time, turning on the receiver after each new wire was attached, then turning the volume up. By process of elimination, I was able to identify which speaker may be the issue. It was one of my fronts. I took it out of the wall, and reconnected the wire to the back of the speaker. That solved the issue. It was not a receiver issue, but an install issue. Thanks. Rob
  • Anonymous Feb 02, 2009
    when i turn volume up unit shuts off
You have to read the manual about 4ohm speakers 6ohm speakers and 8ohm speakers. Im not familiar with your problem but i know its saftey feature so the receiver wont overheat. Hope this helps a little.
Posted on Jul 01, 2008
  • 979 Answers
How much loudness are you trying for. Also, the program material and bass/treble settings factor in when asking a system for increased power...accordianman
Posted on Jun 19, 2008
  • Michael Borelli Jun 20, 2008
    I would now check the crossovers and internal impedance of the speakers. Barring any problems there, I would suspect a power supply problem at the receiver...accordianman
    All right, good deal! Thanks for contacting us for help...accordianman
Onkyo ht r591 keep clicking on/off
Hi Markes,
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
Oct 11, 2015 | Onkyo Audio Players & Recorders
Yamaha RX-V793 receiver shuts down when I turn up volume. Checked the speaker wires and they seem okay. I then hooked it up to an older DVD player I had and it works fine. Don't know if it's 5.1 bu
My first thought would be that when you moved the receiver to connect another DVD, the problem quit since the speaker wires moved. The best way to test would be to re connect the original unit the same way as the new unit and test again. If it still cuts out, disconnect the speaker wires and re test. if it still cuts out, try the new player and test again. if it does not cut out, there may be a problem with the old units audio output. Generally if its a problem with the receiver it would not matter what source you are using, even the tuner on the receiver, if there was a short in the receiver it would cut out. Let me know what your results are and I will help more if needed. Best of luck!
Nov 24, 2011 | Yamaha Audio Players & Recorders
I have a yamaha, natural Sound Av receiver RX-V483, every time that i start the unit it will shut down after 5 seconds. thank you very much
It indicates an output load problem, dis-connect the speaker wires from the back of receiver. Next power on and turn the volume right down, if the unit runs, check for shorts in the speaker wires and speakers. But if it still shuts down "with speakers and wires dis-connected" one or more of the audio output ic's is shorted and will need a professional to assess the item.
Feb 02, 2011 | Yamaha RX-V463 Receiver
Rx-v795a reciever shuts off after 5 min or more can not hear fan in reciever for cooling.
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Nov 15, 2010 | Yamaha RX-V795 Receiver
Keeps turning itself off
If Both speakers are working at a low volume and you turn it up and it clips and shuts off you have one of 3 problems. you have over driven your speakers and one has shorted the voice coil but still will work at low volume, its a overload protection for ohms short in receiver. unhook each speaker and turn balance to the one hooked up and turn up receiver if it shuts off do the same with other speaker to determine which side is bad. 2 speaker wires are touching at speaker or receiver. 3 a bad receiver output transister. Good luck.
May 23, 2010 | Sherwood RX-4109
Look at inside at capacitor and fuse but they seem ok. again once i turn it on, it would automatically shuts off after a second.
When a system shuts down after a few seconds it is the self protect circuit shutting down power to the outputs to prevent (further) damage. It may be caused by frayed speaker wires, bad speaker voice coils, or blown output transistors. First, turn off power and remove all speaker wires from the receiver. Turn it back on and see if the problem remains. If it works OK, inspect each speaker wire at both ends for loose strands and correct these. Then, hook up your speakers one at a time until the problem reappears. That speaker or its' wiring is your problem. For safety's sake. turn the receiver off before connecting each speaker. An accidental short of the output terminals can be disastrous (and expensive).
Apr 06, 2010 | Yamaha RX-V661 Receiver
Overload
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Sep 25, 2007 | JVC RX-6018V Receiver
Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Jun 06, 2007 | Yamaha RX-V630 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V661 Receiver Logo
255 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
