Microphone static - Audio Players & Recorders
  • 979 Answers
MUCH more info please!
Posted on Jun 19, 2008
The Clip Light and Static ?
I don't know what make & model of microphone or clip light you're using, but try unplugging the microphone cable from the preamp. That will tell you if the problem is in the microphone or the preamp/amplifier.
If you still get noise with microphone unplugged, try checking the power supply. You'll probably hear any hum from power supply. Make sure you're using one that's recommended or sold by the manufacturer.
Finally, try replacing the output cable. Any open circuits in the output cable could cause hum & noise.
That's all I can think of right now. Good luck.
May 01, 2014 | Rolls MP13 Mini Microphone 1-Channel...
Mic has static and popping sound. not working
Give Shure Tech Support a call at 800-516-2525. They can help you troubleshoot the problem. Have the mic nearby when you call them.
Oct 22, 2012 | Shure KSM27 Professional Microphone
Hi I have a vhf digitech AM-4071 wireless microphone system and the problem is that both microphones are going only through one RF, on the transmitter. The second mic goes but its not receiving on tr
You need to check that they are both operating on different channels there should be a switch or POT on the microphone and possibly one on the reciever. If they are static or preset you need to swap one for the other channel. Some (usualy cheap) mics have a preset or static channel often ch-A and ch-B, there should be one of each in the box. If you bought the extra body packs they will also come with the preset channels.
- thegorisb
Sep 07, 2012 | DIGITECH VOCALIST LIVE 2
Static noise
This is a problem that's not too uncommon. First, you need to determine if the mBox is at fault, as they can be noisy. Test it with another mic.
If the mic is indeed at fault, and is under warranty, I advise sending it to Rode for repair. Otherwise, I can can perform out of warranty service on any Rode mic.
Condenser Microphone Mod Service
May 22, 2012 | Rode NT1A Professional Microphone
Static with mike
Static can be caused by many things. Are you to far from the receiver. If you put it on a padded surface does the static continue, if so it may be local interference. If not it is probably something loose in the microphone. If all else fails Go to Shure.com look under support, you can get a price list and where to return it for repair.
May 16, 2012 | Shure PGX Series Wireless Microphone...
I get video, problem is, by confirming with recorded audio, i get a static. previously was functioning fine, but now confused on why getting this static.
The microphone in the camera may be bad. Use the microphone input of your computer to check. The camera's microphone goes through the USB - disable it from your cam settings.
Feb 13, 2011 | Microsoft LifeCam VX-3000 Web Camera
Static problem
Try using a headset or lower the volume.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Apr 11, 2009 | A4tech Viewcam PK335 Webcam
Inspiron 1505 speakers
The static noise may be a defect. If your laptop is still under warrent, contact dell for a warrenty replacement. I had the same problem with my inspirion. Sigmatel
Jan 24, 2009 | Dell Inspiron 6400 Notebook
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Microsoft Lifecam Vx-6000 voice static
Second reason is, if you are using a laptop and have an internal microphone and have added an external microphone between the two it will cause distortion and static because both are active.
Jan 03, 2009 | Logitech QuickCam Communicate STX Personal...
46 people viewed this question
 Grubhead
Grubhead
