Question about Mitsubishi VS-50607 50" Rear Projection Television
Mitsubishi rear projection tv model ws-65907
My tv turns on for 1 second then off right away. I pushed input and menu and it gives me a 2-1 code on the power button. Is this something I can fix or is it for a repair person?
    Sergeant:
    Champion:
  • 297 Answers
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
Posted on Jun 19, 2008
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws 65907
do u hear a clicking sound.
this can be due to relays getting tripped
Jun 22, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65511 tv won't turn on
If the green power light on the front comes on for a second or two and goes out: Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both. Power light will blink a two digit error code: 2 blinks, 2 blinks, pause and it will repeat several times. Let me know if you find a error code and I will tell you what it means. IF this information was something you did not know, rate this solution as very helpful as I do this here for free. SD TECH
Sep 07, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi ws-65907 tv will not power on
one of the two pico fuses that protect the convergence chips this model uses is gone--see attached photo--
NEVER change just the fuses---if one of the two fuses is blown--the convergence chips got them-----
there are several ways to proceed from here-check the two fuses indicated in the photo and tell me if either or both are bad.
SD TECH
Jan 03, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Inputs randomly stop registering, screen goes blank
Code 12 indicates no error. Push the Menu and Device buttons after the TV has shut off to get the proper code, not after you unplug and plug it back.
It seems your set is not Mitsubishi WS-55819 so it will help if you can give the exact model.
Dec 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
My Mitsubishi WS-65907 turns off immediately after you turn it on
Perform the self check that this set should have: when you turn it on and the power light goes off:
On the front of the set press and hold both the MENU and INPUT (OR DEVICE) BUTTONS AT THE SAME TIME FOR AT LEAST 5 SECONDS----then release both buttons.
The power light should blink a two digit error code--for example----------2 blinks, a pause and 2 blinks--this is the most common one and the easy one to know what is wrong.
Let me know what you find and I will tell you what it means.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 15, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Picture Convergence WS-65907
TRY NEW CONNECTERS AND INPUTS,,THEN USE THE CONVERSION
May 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws-65907 tv not turning on
Let's just buy new TV's to help stimulate the economy.........
Dec 14, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907
can u please give me ur email ID so that i can send u a DOC file having all step by step instructions?
since it is very long i can post it here
Mitsubishi VS-50607 50" Rear Projection Television Logo
145 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
