Question about U-Line Icemaker
U-Line BI-98 How to Remove Ice Maker Unit??
I have a U-Line BI-98 undercounter icemaker, and I need to replace the ice maker module but I cannot figure out how to get the broken one out. I've removed the two screws holding it to the wall, as well as the three screws going through the bottom, and it won't budge.
  • 2 more comments
  • tracetrimble Jun 20, 2008
    Here is the answer, from U-Line's tech service department. I emailed them yesterday, and they responded within an hour!
    "You need to remove the back panel and disconnted the wires to the icemaker and also pull the senor tube from behind the icemaker. Then twist the icemaker towards the center of the icemaker."
    I'm going to try it this weekend, and if I run into problems I will post here.
  • Anonymous Jun 30, 2008
    i removed the two screw and the ice maker will not come out there must be another screw to take out but i do not see were it is.
  • car24 Sep 24, 2008
    New module but motor just makes noise it does not turn by itself.
  • tracetrimble Oct 16, 2008
    I got mine replaced, but it was glued to the metal panel that runs underneath the icemaker module. The glue is super tacky and thick, and it took a while to get it loose. I just screwed the metal panel back to the new module with no glue, and it works fine. Not sure why the glue was needed at the factory.
I need a manual for an everstar undercounter icemaker hd1m35 by franklin ind.
will not make ice all mode lights lit up
Posted on Oct 16, 2008
There is also a screw on the bottom of the icemaker. remoce it also.
Posted on Jul 14, 2008
My BI98 u-line ice machine won't stop making ice even with bin arm up.
I would suspect the switch controlled by the tray full sensing arm/bail. That's kind of like the main power switch for the ice maker. You can remove the outer cover from the ice maker with the power unplugged! Then look at the mechanical operation of that lever as it relates to the switch. The lever should cause the switch to open and shut off the timer motor. Some times you can buy the timer separately otherwise you replace the whole icemaker. Don't forget to remove power and turn off the water before you remove the old icemaker.
Oct 15, 2014 | U-Line BI-98
U-Line Ice Maker Using Excessive Amounts of Water
the fins on the back of the unit need cleaning..it cannot cool thru the fins if they are covered..i recommend a thorough cleaning inside and more importantly..the cooling fins..
Jan 08, 2014 | U-Line Icemaker
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
No water to ice maker
It will only call for water when the thermostat is satisfied. Now if you advance the icemaker when the ejector blade reaches 10 oclock thats when it should call for water. If you dont here the valve humming then it would be in the water switch inside the icemaker.Also make sure the thermostat is not set too cold. if its too cold it will never satisfy your control.
Manually advance : remove the cover on icemaker then turn the small gear counter clockwise
Oct 04, 2009 | U-Line Icemaker
I have an old U-line ice maker. I can not find
The mechanical parts of those models is the same as a BI 95 or BI98. If your looking for the faceplate that would be part number 150. This includes the timer motor,gears,water switch, and hold switch. You can order this thru a parts distributor. Appliance Parts Depot or All Brand Parts should be able to help. If you want to replace the complete icemaker assemly that part number is 402
Jul 04, 2009 | U-Line Icemaker
BI98 U-Line ice maker freezing but not making ice
The cyle is stuck in the midway section. Unpluh the water supply to ice maker anf see if it will return to the fitst stage, If not we will need to look into the ice maker to see if one of the contacts is stuck. Is this a new ice maker and desighned for your refrigeratorr? Sea Breeze
May 27, 2009 | U-Line Icemaker
BI-98 U-LINE ICEMAKER
THERE IS A SOLONIOD VALVE WHERE YOU CONNECT THE WATER SUPPLY. IN IT IS A FINE SCREEN THAT MAY BE STOPPED UP OR THE VALVE MAY BE BAD. ALSO TAKE THE COVER OFF THE ICEMAKER AND LOOK FOR A CAME WITH A SLOT IN IT. TAKE A SCREWDRIVER AND SLOWELY TURN TO THE RIGHT ( I THINK) AND SEE IF YOU HEAR THE VALVE COME ON AND WATER COMING INTO THE ICEMAKER.
Nov 09, 2008 | U-Line Icemaker
Ice maker
read the mamual
U Line Origin Series BI95 14" Ice Maker with 12lbs. of Ice Storage, 23lbs. Daily Ice Production & No Drain Required "The difference is in the details. Take a closer look." Compact andconvenient, the Origins BI series offers both streamlined styling andADA compliance. As developers and manufacturer of the world's firstbuilt-in undercounter residential and light commercial ice maker,U-Line maintains its posi ... More
Sep 18, 2008 | U-Line Icemaker
BI-95 ULINE
raritan eng/whirlpool ice maker assembly
Jun 20, 2008 | U-Line Icemaker
Kitchenaid removing icemaker
on it as to you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jun 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
U-Line Icemaker Logo
994 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
