Question about Epson Stylus Photo R300 InkJet Printer
DPI SETTINGS CAN I CHANGE PRINTERS DPI SETTINGS ? THANKS, STEVE,
  • Epson Master
  • 691 Answers
Select quality by changing between draft, text photo and best phot modes. For best results select Best Photo and use glossy photo paper.
Posted on Jul 06, 2008
How do I change the dpi settings on my thermal take mouse?
The buttons on the top(under the scroll) are default for changing DPI. If you can't change DPI from them, install the software for your mouse and open it. You can customise your DPI from there.
Jul 24, 2014 | Thermaltake Tt eSports Element Gaming...
200 dpi print head in a 300 dpi zebra zm600
yep, you can do it, but needs new prinhear and change gears inside, or thought settings you can change as well.
Dec 17, 2013 | Zebra Office Equipment & Supplies
How do I change my dpi settings on a printer
Printers are very different and there are also differences between operating systems, but tat setting is usually in the printer's properties, when avallable.
Sep 25, 2012 | Kodak Esp 3250 All-in-one Inkjet Printer
How to change the dpi settings on r340 printer
Dpi setting is available for postcript printer. For inkjet printer, you can setting resolution from printing quality (photo, best photo, photo rpm).
Jun 30, 2010 | Epson Stylus Photo R340 InkJet Printer
How to set resolution 300X300 dpi
ok goto start /control-panle/display /change isplay settings then drag pointer to ur number/then apply
Aug 24, 2009 | Canon LASER SHOT LBP-2900 Printer
How do I adjust the darkness of the printing, it is currently set at 2 out of 4 darkness?
You will need to follow below process.
Print quality settings always affects on print resolution and toner usage.
to change print quality setting:
1. go to Start/settings/control panel/printers
2. then go to printer's properties.
3. go to paper/quality TAB. and select the setting that you want to use. you will get following options.
a) 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
b) 1200 dpi effective output quality: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
c) 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology (REt) for improved text. (this is what you may need to get)
d) Economode: this settings use less toner of your printer. This is useful for mostly draft printings. You can turn this button on freely of other printing-quality settings.
Select the needed settings. Test a print.
And if it is perfect you wont be charge to give recommendation...lol
Aug 12, 2009 | Samsung SRP 350 Thermal Printer
Canon ir C3200 Print Resolution
Print out a Fiery config page ....there may be something in the fiery settings on the actual Fiery box, you'd have to reboot and run setup when it prompts you.
Jul 12, 2009 | Canon Office Equipment & Supplies
Can't figure out how to adjust darkness/tone for printer output
Below you can see a step by step procedure on how to change the print quality of your work....you need to make test printouts in order for you to see the results....at the end there is a link to the manual for your printer...GOOD LUCK!!!
Print-quality settings affect print resolution and toner usage.
Use the following procedure to change print-quality settings:
1. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
2. On the Paper/Quality tab or the Finishing tab (the Paper Type/Quality tab for some Mac drivers),
select the print quality setting you want to use. The following options are available:
● 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
● 1200 dpi effective output quality: This setting provides 1200 dpi effective output quality
using FastRes 1200.
● 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology
● EconoMode: Text is printed using less toner. This setting is useful when you are printing
drafts. You can turn on this option independently of other print-quality settings.
Manual
Apr 13, 2009 | Office Equipment & Supplies
Labels enlarged
if they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Mar 11, 2008 | Zebra Z4Mplus Label Printer
Print out is too small
To resolve this, try the following actions:
* Check the default fonts within Microsoft Windows.
* Select your entire document and set it to a larger font.
* Make sure all your fonts are loaded properly.
* Change the resolution to quick print at 600 dpi. To do so:
1. Click Start, Settings, Printers.
2. Right click the Lexmark printer icon and choose Properties.
3. Choose the Document/Quality tab and set the resolution to 600 dpi quick print/draft.
* Change the Spool Data Format to RAW. To do this:
3. Select the Details tab and click Spool Settings.
4. In the Spool Settings screen, set the Spool Data Format to RAW.
5. Click OK and then Apply.
Nov 19, 2007 | Lexmark X2350 All-In-One InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
234 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
