Question about Ovens
How do I find a double oven which will fit into the existing cabinet?
I have a tall wall cabinet with an old AEG double oven (don't know make,but it looks older than 2ndhand ones I've seen described as 10 years old). I wish to update the kitchen without spending too much as the market is not so good at the moment!
We are getting the flooring replaced by insurance (leak = speed bumps across floor from swollen chipboard) which will entail removing all the floor cabinets. They are happy to install new appliances if it is the equivalent of refitting the old ones.
So, how do I find a new double oven that will fit in the existing space? The current oven is 88cm high and the cabinet is standard 60cm width, 63cm depth.
Also, it seems that 60 and 70cm hobs are quite standard in cut out size, right? or do I need to match that exactly too? My current gas hob is push button ignition - as we have a powerpoint already, I can get an automatic ignition model that they can easily install?
Thanks so much - this is all new to me as you can tell!
Dita
  • 3,828 Answers
Well that metric size given wont be the problem
most double ovens are metricated
if you need packing or extra leveling or oven framing to finish the job
that can be added using MDF or laminates
any double oven for sale on line
may have the fitting requirement for you
The Best Electric Wall Double Ovens of 2017 Top Ten Reviews
Posted on Mar 06, 2017
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Hotpoint EG54P ignition sparking by itself
The reason it stopped was you need to push down to activate the switch and turn on the sparking be careful about getting water down in the unit ..Glad to Fix Ya plz rate my answer
Posted on Feb 24, 2008
  • 16 Answers
SOURCE: Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Posted on Jun 01, 2009
barkencoa
  • 3463 Answers
SOURCE: I am installing a new electric oven and gas hob.
Run a seperate 13amp spur from the D.P switch.
Please rate my solution.
Thanks.
Posted on Aug 27, 2009
I HAVE A AMANA SINGLE WALL OVEN THE ELEMENT SPARKED AT THE BACK OF THE WALL. I PURCHASED A NEWW ELEMENT AND WHENITOOK THE OLD ONE OUT THERE WAS NO WIRE TERMINALS AT THE ENDS OF THE PLUG IN END OF THE...
when it burnt off it fell somewhere between the oven chamber and the back panel.once finding it,its just a matter of splicing a new wire terminal end and attaching it to the element. The problem lies in thats its a built in wall oven and may be needed to be removed from the cabinet to find and repair this wire. Depending how tight it fits into the cabinet it may not come out easily and even break the wood around the cabinet. which of course you could face in pulling it out to replace it with a new oven. ONe thing to keep in mind is that all wall ovens are slightly different in size and the replacement oven needs to be pretty close to the size of existing one or the cabinet will need to cut or filled in so their wont be a gap left when new one is smaller leaving a gap in cabinet up to 2 inches on either top or side walls
Aug 13, 2011 | Amana Ovens
Hi We need to replace wall oven model 755T what size wound it be so we can buy new one Thanks Tracy
The best way to determine the size wall oven that will fit is to partially pull out the existing one and measure the cut out of the cabinet it will fit into
Jul 26, 2011 | Fisher and Paykel AeroTech OS302 Electric...
Where is the model no on our aeg white double oven competence about 8 years old
Open the door, usually engraved within the door panel. Either on the sides or Top.
Most important number is called the PNC. If not found there, look for a sticker on the Oven Cabinet upper, after opening the door.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | AEG Ovens
Hi. Just need to know if the oven door is adjustable on our AEG electric double oven cooker? The bottom oven seems to 'leak' hot air slightly from the top right hand corner and when you press on the same...
there will be a slight adjustment that can be done if you undo any screws or bolts holding the door , no need to take them completely out but just enough to re position the door , make sure there are no hinges that are bent .
Nov 18, 2017 | AEG Ovens
Aeg oven d4100 cutting out
There is a cooling fan in the cabinet of the oven which is not working either the fan is faulty or the controling cut in stat is, The fan should run when the grill is selected if does not it is more likely to be the fan/motor at fault.
Dec 07, 2009 | AEG D2100-4 Electric Double Oven
Wall Oven does not fit flush into built in cabinet
I HAVE SEEN SOME CABINET MAKERS BUILD A TRIM PIECE THAT GOES ALL THE WAY AROUND THE EXISTING HOLE THAT HAS AN OUTSIDE DIMENSION LARGER THAN THE CABINET HOLE AND AN INSIDE DIMENSION TO FIT THE REQUIREMENTS OF THE OVEN. IT ATTACHES TO THE FACE OF THE CABINET AND STAINED TO MATCH THE CABINET FINISH.
Apr 10, 2008 | Ovens
Ovens Logo
202 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
