Question about Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser - Transfer Unit issue
I replaced the Transfer Unit and I do not know how to reset it so that the printer may set to 100% lifetime remaining. Can someone help me with some indication?
  • 1 more comment
  • Anonymous Jul 09, 2008
    I also have this problem
  • Anonymous Sep 03, 2008
    mine say still says 2% even with a new kit.
  • Anonymous Dec 04, 2008
    I am having a problem with my XEROX PHASER 7300.
    The printer indicated a new TRANSFER UNIT...I replaced that part, yet the machine still indicates I
    have a bad TRASNFER UNIT...(REPLACE TRANSFER UNIT)
    and will not operate...desktop message says REPLACE TRANSFER BELT
    MACOS10
    carl
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
Posted on Sep 15, 2008
    New Friend:
  • 97 Answers
There's full details on how to reset the counters in service mode
here
Posted on Apr 11, 2011
Cambie la unidad de transferencia y todavia me señala fin de su vida util, resetie el contador de la unidad igual.hice el test de transfer belt entrance sensor y me indica Transfer unit paper not present
Posted on Nov 13, 2009
Reset imaging unit xerox 7300
You can reset the imaging unit in two ways - either with a fuse, which will return the count to 100%, or in the hidden menu, which will not get you all the way to 100%. You'll find all the details about how to do it, and a lot more information about this printer here.
Nov 23, 2011 | Xerox Phaser 7300DN Laser Printer
My 7300DN starts making a grinding/ratchety noise shortly after power-on. It sounds as if it's coming from the upper right side. I swapped out the transfer unit but got the same noise. Any suggestions will...
Did you perform any maintenance to the printer like cartridges and toners. Also it sound the the transfer unit id defective.
This is a PDF link on how to perform a maintenance.
Post back!
Nov 18, 2010 | Xerox Phaser 7300DN Laser Printer
Have Xerox 7300DN Printer. I am getting white lines in black color only. Have done all steps in the Xerox Diagnosing Print-Quality Problems page. Did not solve issue. Supplies usage page states black toner...
It looks like you may have some damage to the black IU. If you have an old one or a spare to try as a test that might help. The drum is easily scratched and this then produces marks or lines in the appropriate colour.
Nov 05, 2010 | Xerox Phaser 7300DN Laser Printer
Colors do not align
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Nov 03, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 6303 printer shows "replace transfer unit" what does it mean,.
The transfer unit is the part of the printer which transfers the image created by the imaging drums onto the paper. After a certain amount of use it has to be replaced to maintain print quality. At that time, the printer is programmed to show the message you have received.
Aug 24, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300 color misregistration
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
How do I clean a toner spill off my transfer unit on a phaser 7300?
Hello sir; You can use vacuum cleaner for office equipment use .
Aug 28, 2009 | Xerox Phaser 7300DN Laser Printer
Advice phaser 7300dn appear 10: eeprom ,help me please!
The only thing you can do is attempt a reboot and hope for the best, otherwise call out an engineer to repair it! Or you could try and NVRAM reset but I'm not sure if that will work and be careful because you will set the machine to factory settings and may have to do a colour calibration all over again. Let me know how it goes.
Resetting all settings to default (NVRAM)
Resetting the NVRAM will reset all printer values including network, printer setup, job defaults, and color calibrations.
  1. Press the Down arrow key and scroll to Support.
  2. Press the OK key.
  3. Press the Down arrow key and scroll to Service Tools Menu.
  4. Press the OK key.
  5. Reset NVRAM will be displayed.
  6. Press the OK key.
  7. Reset NVRAM and Reset Printer NOW will be displayed.
  8. Press the OK key to reset all the settings to default.
Dec 11, 2008 | Xerox Phaser 7300DN Laser Printer
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300
Check in side the fuser unit there are two latches to release it and the unit comes out as one. check in there also you may have a paper feeding issue try to use the MPT as the paper sourse.
Sep 26, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
1,287 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
