Question about Garmin GPS
Need instructions how to operate the damn machine
  • huttonalexan Jul 19, 2008
    Did not receive instructions with the Garmin 350
Sent my gps away because it would not turn on it has come back i have put new batteries in but can not remember how to turn on HELP!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 19, 2008
Tip
Damn Small Linux Guide for survival (Live Linux) CD USB flash
Damn Small Linux is a live linux distribution,
less than 50MB runs completely in memory
and can be booted from a CD-ROM or a USB flash drive.
(Because all the applications are small and light
it makes a very good choice for older hardware.)
1) How to put Damn Small Linux on the CD
1.a) Download Damn Small Linux
ftp://ibiblio.org/pub/Linux/distributions/damnsmall/current/dsl-4.4.10.iso
1.b) Damn Small Linux is distributed as an ISO image.
It is necessary to burn it to CD
using the option of your program to burn CDs
Burn CD ISO image (Windows - Nero / Burn Image to Disc, for example)
1.c) Then you need to restart your computer.
1.d) Depending on the options your motherboard,
it is necessary when starting
your computer keyboard press:
F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your CD drive.
After
Damn Small Linux menu comes before you.
2) How to put Damn Small Linux on a USB flash drive
2.a) Download Damn Small Linux
ftp://ibiblio.org/pub/Linux/distributions/damnsmall/current/dsl-4.4.10-embedded.zip
2.b) Format the USB flash drive in the FAT32 filesystem. (Windows)
(MyComputer, right click on your USB flash drive, Format, File System = FAT32, start)
2.c)Download and run USB Installer for DSL
to create a bootable Damn Small Linux USB Flash Drive
http://www.pendrivelinux.com/downloads/DSL/USB-Installer-For-DSL-v0.2.exe
2.d) Then you need to restart your computer
Depending on the options your motherboard, it is necessary when starting
your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your USB flash drive.
After
SliTaz menu comes before you.
3.) You can start using your Damn Small Linux easily
on Jan 23, 2010 | Computers & Internet
Tip
Excellent - and simple instructions that should be part of the damn manual. Who...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Aug 21, 2009 | Kenmore Elite 45986 Front Load Washer
Watch instructions
i don't care about your problems, all in need is instructions on how 2 work this damn! watch
Jan 19, 2008 | Casio Technowear CMD30B1T Wrist Watch
I FOUND THE DAMNED MANUAL!!!!!!!!!!!!!!!
I have both the manual and driver. I also have a firmware update to make it 1.10
It says Traveler but this camera was made under at least 2 brands from the company in China. Optimus and Traveler. Both are part number 16-3899 but are model DV-5040
Driver
Manual
Firmware Update **read instructions that come with it** I'm not responsible.
Jan 13, 2008 | Optimus DV-3040 Flash Media Camcorder
GPS Logo
121 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
