Proscan 52" Do you have a link for a service manual for this TV? My tv runs for 3-4 hours, then it powers off and on, does this a few times, then shuts off. Wait 15 minutes and it startsworking again Thanks Comment by tchguru, posted on Jun 17, 2008 Thanks for the quick reply. It is a PTK188AB
  • 8,617 Answers
Unfortunatly I dont have a link for your model, however I will continue to search for one, and will send a response if I can locate one
Posted on Jun 19, 2008
Tv will not stay on Proscan PS52690
power supply probably needs to be rebuilt, vertical IC some filters,probably a couple of transistors. best to have an experienced tech do it for you.
Aug 30, 2009 | Proscan PS52690 52" Rear Projection...
I HAVE A 80 INCH PROSCAN REAR PROG TV AND THE ON/OFF SWITCH WILL
it sounds like the main power supply. unfortunately spare parts are no longer available for this model
Feb 21, 2009 | Proscan PS52690 52" Rear Projection...
Proscan PS52682 - Turns on then quickly goes off
sounds like a control pannel problem further trouble shooting
Aug 14, 2008 | Proscan PS52690 52" Rear Projection...
Service manual for Proscan PS52690
I believe your model is a PTK188 can you look for the chassis number off the tag on the back, and I may be able to help you locate a manual, but the older RCA / Proscan / GE need the chassis number
Jun 14, 2008 | Televison & Video
52" ProScan TV
You would have to do that through the service menu. However I would not recommend doing that without the service manual. I can post a link to the service manual if you would like.
Feb 18, 2008 | Proscan PS52800 52" Rear Projection...
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Dec 05, 2007 | Televison & Video
Proscan PS5067 52 in. Rear Projection TV
Try unpluging the tv for about an hour. I have the same problem and a tv repair man suggested the solution. It work every time I have the problem, although it is happening more often now.
Nov 08, 2007 | Proscan PS52800 52" Rear Projection...
ProScan 52" Projection Turns on the right off after clicking a few times
I've had the same problem with a 60" proscan. The tech repaired it ($400 for the repair) and left a note inside the chasis explaining what he did (in case he had to fix it again). He replaced a resistor and re-soldered a number of ICs. It happened to me again, and I may attempt the repair myself this time around.
Mar 19, 2007 | Proscan PS52800 52" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
