SOURCE: I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
SOURCE: Seiko Chronograph Sport 150 - Problem: After
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Testimonial: "PDF link states reseting the watch is the problem, and now that I have instructions, I should be able to reset the watch. Thanks"
SOURCE: Seiko Chronograph 7T32 minute hand inactive after battery replace
you often need to do a full reset on 7T32s (& other seikos) after a battery change. there is a small reset contact in the rear of the movement which needs to be shorted to the top of the battery (the movement is engraved with wording to this effect, something like "AC reset", I can't remember exactly). you might also try pulling out the crown all the way (2 clicks) then holding both upper pushers in for a few seconds. it's unlikely to be a buggered motor unless it's one of the subdials that's failed.
hth-
duncan.
