Question about RCA Televison & Video
I accidently set the FPA code lock on the tv which has caused my tv to not turn.
5 Suggested Answers
TVtechmaniac
  • 140 Answers
SOURCE: FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Posted on Sep 13, 2007
SOURCE: FPA Lock can't turn Tv on
I posted the above - I went to WalMart, bought an $8 remote and a .98 pack of AA batteries. It turned the TV on immediately. Problem solved for less than $10.
Posted on Dec 04, 2007
SOURCE: fpa lock
i need some help people......i need to know how to take off the Lock
Posted on May 14, 2008
SOURCE: FPA lock
rca fpa will not trun off plz help me trun it off
i nedd help plz
ty for your help
betty
Posted on Jun 06, 2008
Adolph
  • 137 Answers
SOURCE: FPA lock on a magnavox
The only way to fix it is wit remote , get your self a universal remote and do manual search until set switched on , then go to menu and turn lock off before it happened again.
Posted on Jun 29, 2008
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 28, 2012 | Televison & Video
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
I accidently locked the fpa how do i unlock it without a remote
Unfortunately, there is really no other way to unlock fpa other than using a remote control.
You can buy any universal remote control and this can be use to unlock fpa.
Good luck.
Sep 20, 2010 | RCA TruFlat 27F520T 27" TV
Tv turns off and on by itself. It alsoo changes
This sounds like the front panel assembly(FPA) switches are acting up. What happens is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Let me know if you need more help or info.
Post back with make/model info. (the problem is common especially with RCA)
Nov 28, 2009 | Televison & Video
It wont turn on its stuck on stand by any suggestions? when we do get the tv turned on we cant knock it off or it takes hours of fiddling with the remote standby button to get it back on the tv is a...
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
Nov 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
TV TURNS ON BY IT SELF AND CHANGES CHANNELS AND FPA LOCK IS ON
the problem is there is engaged button there..only technician can do the job by replacing the button that is always engage.
Oct 22, 2008 | RCA 20F420T 20" TV
Jun 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Fpa lock
Jan 20, 2008 | RCA 27F530T 27" TV
Sep 12, 2007 | RCA 27F650T 27" TV
RCA FPA LOCK
Take the remote and turn the set on. With FPA (Front Panel Access, or Child Lock) on, the set will only turn on with the remote. Enter the menu, navigate to the page with FPA and set it to OFF.
Sep 02, 2007 | RCA 20F511T TV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
