HP LaserJet 4350dtn Printer
Problem for HP LaserJet 4350dtn Printer
InDesign Printing problem; service error 49.4c02
By JimyDSnake on Jun 19, 2008
I have an HP4550n Color laser printer and I get the error code above, but only when printing from Indesign 2.01 and only with some files! Doesn't matter whether I'm printing from Windows 2000, 98 or a Mac! This error code only comes up when printing from InDesign.... any ideas?
Same service error 49.4C02 when printing some PDF documents. Doucment prints ok when "Print as Image" is slected from the Advance button of the print dialog box.
Comments:
Jun 23, 2008
- Being in an entreprise environment with over 100 HP printers this error occurs with Adobe 8.1 PDF documents only and changing hardware is unacceptable to our clients. We've installed adobe v7 and it seem to have printed fine. Due to security reasons we had to upgrade the application to v8.1 and then this service error started to occur. Any more feedback would be appreciated. thanks
Same Problem
Feb 19, 2009
-   Same problem, any resolution?
-   smoeller
Oct 06, 2008
-   I have System turn off, and then ON, with hold ON the green Button
Allready ask me what language i like...
Alll ever it's ok... Yeap
-   cinemaca
Solution #1
posted on Jun 19, 2008
Somewhat Helpful)
scotta01
Rank: Master
Rating: 81%, 24 votes
This is a solution which has been suggested on another site, this has not been tested by myself so no promises.
1. Turn the printer off.
2. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
3. Remove all EIO devices from the printer.
4. Turn the printer on.
5. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
6. Replace a DIMM or EIO device if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
Hope it helps, as I said, not tested personally.
Was this helpful?
Yes
No
Solution #2
posted on Oct 11, 2008
Not Rated)
sshroder
Rank: Wiz  HP Expert
Rating: 81%, 54 votes
also may be the network card or formatter. my thoughts are that you should make sure you are using the pcl5 or 5e driver as opposed to the pcl6 or ps drivers. that is the most reliable driver code but lacks some of the bells and whistles of the pcl6. these may be things to test or check to help nail down your problem. also check to make sure the printer routing is correct in indesign. Good Luck!
Was this helpful?
Yes
No
Popular Solutions for HP LaserJet 4350dtn Printer
Questions and Unsolved Problems for HP LaserJet 4350dtn Printer
Do you recommend HP LaserJet 4350dtn Printer?
Answer
Answer
i have a mfc-495cw printer and 4x6 photo paper but i cant get the printer to print a full size... (More)
Answer
have a hp psc 2110 all-in-one i replaced ink and it printed out instruction and alignment page i... (More)
Answer
my okidata microline 320 wraps around, how can i compress the print ? The printer doesn't have a... (More)
Answer
yes i have hp lj 4350 dtn, which does not recognize a known duplex
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
