Question about Refrigerators
Hi, I have a Kenmore Model# 596.79144000 P1325009WC. I jsut put in a 115 Vac/60HZ Amp 7.7 new, I also put a new fliter on the ice machine now it does not make ice. Is there a restart switch somewear. Please advise me. Thank You
SOURCE: kenmore side by side refrigerator model 106.56532400
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
Posted on Feb 19, 2008
  • 103 Answers
SOURCE: Moldy Ice from Ice Maker
Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
Posted on Jun 07, 2009
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
Posted on Dec 30, 2009
  • 999 Answers
SOURCE: Have a new Kenmore elite with bottom freezer. Just
Did the IM fill with water? It can take up to 24 hours for the first batch of ice but if temperatures are correct it can be in 2-4. The lines do have to purge the air or you will not get a full fill at first.
Posted on Mar 18, 2010
  • 3740 Answers
SOURCE: have a side by side kenmore ref. and the ice
Hi and welcome to FixYa. I am Kelly. Having determined your icemake is PN W10190960 , here is a link that will help you test your icemaker:
The steps are pretty straight forward and will isolate exactly which component of the icemaker / system has failed.
I would like to note that these icemakers are very reliable. They do occasionally fail but most of the time the problem is the freezer is not defrosting properly so the airflow through the freezer is blocked by ice build-up in the evaporator coils due to that defrosting problem.
Your unit has an electronic control board that controls the defrost circuitry.
If you check out the icemaker assy per the first link and still have the problem I would recommend doing a manual defrosting by unplugging the unit. Then remove the contents of the freezer section and place a fan blowing into the freezer section for just over 2 hours. This makes a water mess so be prepaired.
After the manual defrosting cycle restart the unit and reload the freezer contents. After about 12 hours check the icemaker to see if it made any ice at that point. If this solves your icemaking problem it will only be temporary if you still have an automatic defrost cycle problem. Your unit should defrost at least 3 times in 24 hours.
Thanks for using FixYa.
Posted on Apr 01, 2010
Has anyone a circuit diagram and possibly information about the transformer output voltages for a Pihsiang mobility charger model MB-24/3 battery charger?
Hi again i have no data on Ac voltage output AT A GUESS I WOULD THINK IT WOULD B APROX 35 TO 38 VOLTS one thing i did find u can still buy them at MONSTER SCOOTER PARTS ITEM NoCO4-1179 PRICE $183-99 PHONE NUMBER 800-798_0325 GOOD LUCK. input : 100-120 VAC, 50/60Hz 1.5 AMP. U CAN BUY NEW ONE'S ON E/BAY,,..hi output is 24 volts 3.0 amps hope this helps..........
Dec 11, 2015 | Health & Beauty
Motor was losing power and burning
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
I have a heat sentry model 1500 fg, 115 vac 60hz 2.6 a listed fan 5456, the plastic cover has started leaking. where in san bernardino california area, i can find a part ?
I have a heat sentry cover1750f6 probably similar to what you have that blew off with a high wind we had.
Cannot find any place that has them. If you got one, let me know. where.
Sep 08, 2012 | Cars & Trucks
Pro form 995 motor won't turn on
Dear Sir:
You must do the following:
1) You must check the receptacle wall, for 115volts AC,60hz
2) If Not voltage 115 Vac, check breaker or fuse from the Panel( Main) or Sub-Panel for that circuit.
3) If there are 115 Vac, so proceed with the wires of the plugs, retigh conection and see if the contact of the plug is clean or oxide, ( clean with ethilic alcohol 100%) .
4) Check the Main button if there Voltage use the VOM( Voltimeter) , after check the push button Start , clean this .
5) If not work, check the relais and clean with ethilic alcohol 100% in the Board Controller, after check the Breaker.
6) If everything is o.k now proceed to Start the Motor.
7) In short proceed Step by Step with the logic for Troubleshooting.
Please reply is everything is o.k or you need more assistance, Sincerely . God bless you.
E. Cuadra
Sep 05, 2011 | Proform Exercise & Fitness
Wiring diag. for mod. 407-E Ice Cream Maker
Need the serial number, voltage (ie; 115v or 208v), 60 or 50 hz.
The only exact diagram for an 407-e is 50hz.
An M will be close in most cases as long as we have the serial number or Mfg. date code.
If it is a 407-e 115/60Hz with a blue id plate it is at least 15 yrs old.
Nov 09, 2010 | SaniServ 407 10 Quart Ice Cream Maker
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
Need Front Control Board, Kenmore Refrigerator Model 106.4410230
Solved it through parts isolation and identification.
Apr 05, 2009 | Kenmore Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
