Question about Motorola Mobility W375 Cellular Phone
Sim Card How do I get the information e.g contacts, etc off my old sim card and into the phone? The card is installed already, but nothing is showing up. Is there something else that I have to do to get the information off the card?
Hello Natalie im glad to say I have a solution for you now follow the steps I give to you and in a moments time you will have all your contacts off your sim card and into your motorola. OK here we go, while your phone is in idle mode go to contacts then push the options button located in the middle of the black surrounding navigation buttons located on your keypad then scroll down to copy, now at this moment your contacts should be in your sim card. After entering the highlighted copy to options will open choose the one that says "all to phone" and that should solve your problem. If not choose the "enties" options in copy press change with "entries:...." highlighted add everyone else in your sim card and press done then your problem will now be fixed. hope I really helped bye!
Posted on Jul 02, 2008
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Tip
How to Recover Deleted Text Messages from an iPhone SIM Card?
We often meet these awkward accidents inour daily lives. Mistakenly deleted important text messages that includingmeeting spot, dating time, etc. or sometime, Phone dropped down with allcontact numbers missing. If you have saved the information on your iPhone SIMcard, you are lucky, you can get them back for SIM card doesn't erase a fileimmediately once you deleted it. It just make vacant for subsequent file. Unlessthe space is overwritten by new data, your old deleted files like text message,contact number, etc. are still there and can be retrieved.
Causesof losing text messages or contact numbers:
1. Mistakenly press "delete" button;
2. Mobile phone broken and lose data including text message, contact numbers;
3. Mobile phone was drop down to water(most common cases)
4. Improperly operate mobile phone
Preparationfor text message recovery
Before retrievingdeleted text message from SIM card, we should prepare two things: SIM CardReader, SIM Card Data Recovery software. SIM Card Reader is a small device thatplugs into your computer's USB port, some phone own that when purchased theproduct, if not, you can find it at your local electronics store or anywhereonline. For SIM Card Data Recovery, there are various options. Card DataRecovery is the most acceptable one for its easy to use interface as well asreasonable price.
Howto get back deleted text messages?
1. Download Card Data Recovery andinstall it on your PC(Note: this programonly works under Windows, not Mac or Linux)
2.
Remove SIM card from youriPhone, in many cases, SIM card was located on the back of the battery. Slideit out of its place.
3.
Put SIM card in card reader andconnect it to your computer's USB port. Make sure the card reader can read SIMcard.
4. Run Card Data Recovery, you cansee SIM card show as a drive letter in the explorer, select it and click "recoverall". All missed information will be recovered within minutes.
Besides recovering text messages, lostmusic, video or contact number in damaged SIM card also can be recovered.
Mobilephone with SIM card supported:
iPhone, Android,Blackberry, HTC, Vertu, Nokia, Sony Experia, phone Samsung, Motorola, etc.
on May 10, 2011 | Computers & Internet
What do I use to transfer my contacts from my old phone?
If you don't have something like "Data Pilot" which has cables and software for backing up cell phone information...
Normally you would put your SIM card int he old phone, go to the contact/addressbook menu and look for an option for "Copy to SIM"... Once you copy your contacts to the SIM (there's a limit) then you put it back in your new phone. You can then leave them on the SIM or copy them to the phone in much the same manner.
Good Luck!!
:o)
Jan 04, 2011 | Samsung Trance SCH-u490 Cell Phone
How do i copy all my contacts to my sim card?
Go to your contacts management in your phone . Hope this helps!
Contacts Management
Menu 8.5
This menu allows you to copy all of the
information from your SIM card, e.g. name,
handset number, etc. to your handset. If
a name is duplicated during the copying
operation, the information is also duplicated.
You can copy the entry from the SIM card to
the phone memory. You can copy the entry
from the handset memory to the SIM card (not
all the data will be copied).
You can delete all entries in the SIM card
or the Handset. Press the [END] key to
return to standby mode.
Service
good luck!
Mar 25, 2010 | LG Neon GT365 Cell Phone
Changed tmobile sim card to a wing but contacts do not show
Before you remove the sim card from your old phone, you need to import all of your contacts from the old phone to your sim card. On most phones the contacts are stored on the phone, and not the sim card.
Feb 01, 2010 | T-Mobile Wing Smartphone
I got the motorola cliq and transfered my SIM card into my phone. For some reason, only two of my contacts transferred over, the rest are facebook friends. I went under ALL CONTACTS, TMOBILE CONTACT,...
I work at the T-Mobile Corporate store, ive seen this many times with customers. What happened is that your contacts are stored onto your old phones memory because that's the default save location. You can take it to the nearest Tmobile store and they will move the contacts from your old phone to your sim card then to your cliq.
Nov 28, 2009 | Motorola Mobility CLIQ Cell Phone
Cannot import contact from sim card to iphone 3G
Turn off the iPhone before inserting the sim, insert sim, turn on, import contacts. If you put the sim in the phone without restarting it for some reason it doesn't get all the contacts sometimes.
Aug 02, 2008 | Apple iPhone 3G
Exporting Contact Phone numbers back to sim card
write them down and then save them on your sim from your old phone
May 30, 2008 | Apple iPhone Smartphone
How to update my contacts from my SIM card
Just copy the contact from old phone into the sim card.if you are uable to do that .go to contacts and select option button there you will see copy option click on that it will ask you whether you want to copy contacts from sim card to phone or phone to sim card .select phone to sim card......that's it now switch off your mobile and you will see all the contacts of old phone into new one.........
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
May 01, 2008 | Apple iPhone Smartphone
Can't read sim contacts
hi,i just restore my iphone,and next thing it can,t switch on,iphone couldn,t recognise my sim card and it shows only emergency and itunes sign in iphone.please help.
Dec 05, 2007 | Apple iPhone Smartphone
Motorola Mobility W375 Cellular Phone Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
